Absolute uncertainty of calculated density
In summary: Thanks again!In summary, the experiment to measure the density of a cylindrical object uses the equation d=m/(pi*r^2*l), with m=mass, r=radius, and l=length. The absolute uncertainty of the calculated density can be found by adding together the relative uncertainties of each input. In this case, the relative uncertainty is 20.2%. Another method of finding the maximum and minimum possible densities is to use the "engineer's rule of thumb", where the relative errors are added when multiplying or dividing. The maximum possible density is found by using the largest values for each input, while the minimum possible density is found by using the smallest values.
Robb
225
An experiment to measure density, d, of a cylindrical object uses the equation
d=m/(pir^2l)
where
m=mass=0.029 +-.005kg
r=radius=8.2 +-.1mm
l-length=15.4+- .1
What is the absolute uncertainty of the calculated value of the density?
above
d=.029/((pi)(8.2)^2(15.4))=8.9 * 10^-6
Relat. Uncertainty(m)=.005/.025=.172
Relat. Uncertainty(r)=(.1/8.2)+(.1/8.2)=.024
Relat. Uncertainty(l)=.1/15.4=.006
Relat. Unc(m) +Relat. Unc.(r) +Relat. Unc.(l)=.202=20.2%
In this case, it is way easier to just "brute force" the uncertainty in the result. You have uncertainty ranges on each of the inputs. And you have a simple formula for the result in terms of the inputs. So you know, for each +/- of each input, which of the + or - produces a larger density value output. So you put all the "tends to produce a bigger" input values together, to get the maximum possible density. And all the "tends to produce a smaller" input values together to get the minimum possibly density.
Example: R = (a+b)/c
Each of a, b, c, is positive, and their measured values are:
a = a_m +/- a_u
b = b_m +/- b_u
c = c_m +/- c_u
Bigger a and bigger b give bigger R. But smaller c gives bigger R. So the extremes of R are just the following.
R-max = (a_m + a_u + b_m + b_u)/(c_m - c_u)
R-min = (a_m - a_u + b_m - b_u)/(c_m + c_u)
You can easily figure out your max and min from this pattern.
You know, I presume, that dividing by a larger number makes the quotient smaller while dividing by a smaller number makes quotient smaller.
The largest that m can be is 0.029 +.005kg= 0.034 kg and the smallest that r can be is 8.2 - 0.1mm= 8.1 mm. So the largest d can be is [itex]\frac{m}{\pi r^2}= \frac{0.034}{(3.14)(8.1)^2}[/itex]. Calculate that.
The smallest is m can be is 0.029- 0.005= 0.024 kg and the largest that r can be is 8.2+ 0.1= 8.3 mm. [itex]\frac{0.024}{(3.14)(8.3)^2}[/itex].
There is an "engineer's rule of thumb" that when measured quantities are added (or subtracted), the errors add, and when quantities are multiplied (or divided) the relative errors add. Here the "relative error" in m is [itex]\frac{0.005}{0.029}= 0.1724[/itex] and the relative error in m is [itex]\frac{0.1}{8.2}= 0.012195[/itex] so the relative error in p is 0.1724+ 0.0122= 0.1846. Multiply [itex]p= 0.29/((3.14)(8.2))[/itex] by that to get an approximation to the actual error.
a = a_m +/- a_u
b = b_m +/- b_u
c = c_m +/- c_u
Gracias my friend! What I figured out was that I needed to convert the mm to meters. When I did that I cam up with approximately 1800kg/m^3 which was the correct answer. I will definiteley remember your method though.
FAQ: Absolute uncertainty of calculated density
What is the definition of "absolute uncertainty of calculated density"?
The absolute uncertainty of calculated density refers to the margin of error or range of values that the calculated density may fall within. It takes into account the precision and accuracy of the measurements used to calculate the density.
How is the absolute uncertainty of calculated density calculated?
The absolute uncertainty of calculated density is typically calculated by taking the square root of the sum of the squares of the uncertainties in the measured values used to calculate the density.
Why is it important to determine the absolute uncertainty of calculated density?
Knowing the absolute uncertainty of calculated density is important because it allows us to understand the reliability and accuracy of the calculated value. It also helps us to compare and evaluate the results of different measurements or experiments.
What factors can contribute to the absolute uncertainty of calculated density?
The absolute uncertainty of calculated density can be affected by factors such as the precision and accuracy of the instruments used, errors in measurement or calculation, and variations in the physical properties of the substance being measured.
How can the absolute uncertainty of calculated density be reduced?
The absolute uncertainty of calculated density can be reduced by using more precise and accurate instruments, taking multiple measurements, and minimizing sources of error during the measurement and calculation process.
