Absolute Value Inequality, |x|>|x-1|....where's my mistake?
In summary, the conversation discusses how the rule a>0 implies |x|>a if and only if x>a OR x<-a. However, when the absolute value of |x-1| is introduced, the rule cannot be applied since |x-1| can take on different values depending on x. This leads to the conclusion that the rule cannot be used in this scenario.
mishima
570
36
Rule:
Suppose a>0, then |x|>a if and only if x>a OR x<-a
So |x|>|x-1| becomes:
x>x-1 which is false (edit: or more accurately doesn't give the whole picture, it implies true for all x)
OR
x<-x+1
2x<1
x<1/2 which is false
Mathematics news on Phys.org
On the right side of the equation, the absolute value of ## x-1 ## can change signs around the point ## x=1 ##. For a problem like this, I like to break it into segments where the absolute values will always keep the same sign=e,g. ## -\infty ## to ##0 ##, ## 0 ## to ## +1 ## , and ## +1 ## to ## +\infty ##, and evaluate the inequality for these 3 separate regions, and determining for each whether ##|x|=+x ##, or ## |x|=-x ##, and similarly for ## |x-1| ##.
Your mistake is that you use a rule that is valid for a fixed value. You identify a with ##|x-1|## but this is not a fixed value, since it depends on x. Therefore, the rule you listed cannot be used. See @Charles Link answer to see how you need to tackle this problem.
Likes Charles Link
How can |x-1| ever be not be > 0? Aren't absolute values always greater than 0?
Ah, I get it. You're right it could be the case that |x-1|=0, which would indeed break the stipulations of the rule. Thanks.
It's not just a case of ## |x-1|=0 ##. The problem is that ## |x-1| ## can be equal to ## x-1 ## or it can be equal to ## 1-x ##. ## \\ ## ## |x-1 | ## is not simply some positive constant, so the rule does not apply. You can't just remove the absolute value signs on the right side of the inequality, and think that it won't have any effect. The rule you are trying to impose only had absolute value signs on one side of the inequality.
Likes member 587159 and mishima
Related to Absolute Value Inequality, |x|>|x-1|....where's my mistake?
1. What is an absolute value inequality?
An absolute value inequality is an inequality that involves an absolute value expression, such as |x| > 3. This means that the distance between x and 0 on the number line is greater than 3 units.
2. What does the notation |x| > |x-1| mean?
This notation means that the absolute value of x is greater than the absolute value of x-1. In other words, the distance between x and 0 is greater than the distance between x-1 and 0 on the number line.
3. How can I solve an absolute value inequality?
To solve an absolute value inequality, you need to isolate the absolute value expression on one side of the inequality and then consider two cases: when the absolute value is positive and when it is negative. You can then solve for the variable in each case and determine the range of values that satisfy the inequality.
4. Can there be more than one solution to an absolute value inequality?
Yes, there can be more than one solution to an absolute value inequality. This is because the absolute value expression can have different values depending on whether the variable is positive or negative. Therefore, there can be multiple values of the variable that satisfy the inequality.
5. What is the most common mistake when solving an absolute value inequality?
The most common mistake when solving an absolute value inequality is forgetting to consider both cases when the absolute value is positive and negative. This can lead to missing potential solutions and incorrect answers.
  • General Math
