Absolute value within absolute value
In summary: Ah, right! $-4<x<3$, where there is no common strict inequality. $-4<x\le 3$, where there is a common strict inequality (I think).In summary, the conversation discusses a question that can be solved using different methods. The question involves finding the sign changes of a given equation and determining its solutions. The participants also discuss the reasoning behind their solutions and clarify any confusion. The final solution involves merging different intervals to get the complete set of solutions.
Dethrone
717
I did this question two ways, each of which yielded a different answer. I'll post method one first.
$$\left| (2|x-3|-5|x+4|) \right|$$
Sign changes occur when $x<-4$, $-4<x<3$, and $x>3$
If $x<-4$, then $|3x+26|>4$, and so $x>-22/3$ and $x<-10$. Clearly since $x$ much be less than $-4$, only $x<-10$ is a solution to this case.
If $-4<x<3$, then $|x+2|>(4/7)$, and so $x>(-10/7)$ and $x<(-18/7)$, clearly we have the solutions $-4<x<(-18/7)$ and $(-10/7)<x<3$.
Before I continue with the final case, is my logic right?
Mathematics news on Phys.org
Were you given an equation?
Sorry, left out one part.
$\left| (2|x-3|-5|x+4|) \right|>4$
You're partially right, note that in the intervals $\left(-\dfrac{22}{3},\,-4 \right]$ and $\left[-4,\,-\dfrac{18}{7} \right)$, you have to combine these so that the second interval that agrees to the given inequality would be $\left(-\dfrac{22}{3},\,-\dfrac{18}{7}\right)$.
Your reasoning for the rest is correct though, good job, Rido12!
Hi Anemone! (Wave)
Right...I left out $\left(-\dfrac{22}{3},\,-4 \right)$.
But why are we allowed to combine the intervals? If both intervals never reach $-4$, how come we can fill in the "hole"? (Wondering)
Rido12 said:
Hi Anemone! (Wave)
We need to combine the intervals, because the function is continuous on the entire domain.
Perhaps you want draw a real number line so that you can see the whole situation more clearly? :)
I have two open circles on my number line at $x=-4$? (Wondering)
$\displaystyle \begin{align*} \left| 2 \left| x - 3 \right| - 5 \left| x + 4 \right| \right| &> 4 \\ \left( 2 \left| x - 3 \right| - 5 \left| x + 4 \right| \right) ^2 &> 4^2 \\ \left( 2 \left| x- 3 \right| \right) ^2 - 20 \left| x - 3 \right| \left| x + 4 \right| + \left( -5 \left| x + 4 \right| \right) ^2 &> 16 \\ 4 \left(x - 3 \right) ^2 - 20 \left| x - 3 \right| \left| x + 4 \right| + 25 \left( x + 4 \right) ^2 &> 16 \\ 4 \left( x - 3 \right) ^2 + 25 \left( x + 4 \right) ^2 - 16 &> 20 \left| x - 3 \right| \left| x + 4 \right| \\ 4\left( x^2 - 6x + 9 \right) + 25 \left( x^2 + 8x + 16 \right) - 16 &> 20 \left| x - 3 \right| \left| x + 4 \right| \\ 4x^2 - 24x + 36 + 25x^2 + 200x + 400 - 16 &> 20 \left| x - 3 \right| \left| x + 4 \right| \\ 29x^2 + 176x + 420 &> 20 \left| x - 3 \right| \left| x + 4 \right| \\ \left( 29x^2 + 176x + 420 \right) ^2 &> \left( 20 \left| x - 3 \right| \left| x + 4 \right| \right) ^2 \\ 841x^4 + 10\,208x^3 + 55\,336x^2 + 147\,840x + 176\,400 &> 400 \left( x - 3 \right) ^2 \left( x + 4 \right) ^2 \\ 841x^4 + 10\,208x^3 + 55\,336x^2 + 147\,840x + 176\,400 &> 400x^4 + 800x^3 - 9200 x^2 - 9600x + 57\,600 \\ 441x^4 + 9408x^3 + 64\,536x^2 + 157\,440x + 118\,800 &> 0 \\ 3 \left( x + 10 \right) \left( 3x + 22 \right) \left( 7x + 10 \right) \left( 7x + 18 \right) &> 0 \end{align*}$
Now solving the factored equation will tell you the x intercepts. Substituting points in between the x intercepts will tell you where the function is positive and negative.
Rido12 said:
Sign changes occur when $x<-4$, $-4<x<3$, and $x>3$...
Hi Rido12 again,
I'm sorry, I re-read your first post and noticed I haven't pointed out that sign changes occur when we have the weak inequalities over the domain as you have cited, i.e. $x\le -4$, $-4\le x \le3$, and $x\ge 3$, note that when $x=-4$, $\left| 3x+26 \right|=\left| 3(-4)+26 \right|=11>4$.
So to edit my statements:Sign changes occur when $x\le -4$, $-4\le x\le 3$, and $x\le 3$
If $x\le -4$, then $|3x+26|>4$, and so $x>-22/3$ and $x<-10$. Clearly since $x$ much be $\le -4$, so $x<-10$ and $(-22/3)<x\le 4$
If $-4\le x\le 3$, then $|x+2|>(4/7)$, and so $x>(-10/7)$ and $x<(-18/7)$, clearly we have the solutions $-4\le x<(-18/7)$ and $(-10/7)<x\le 3$.
Now, since both $(-22/3)<x\le 4$ and $-4\le x<(-18/7)$ have a strong inequality at $-4$, we can amalgamate them?
@Prove it, I have tried that method as a third method, but it's quite tedious as a quiz question. But nevertheless, a quite solid method when you don't want to think...! :D
Correct! Since both sets of interval are defined when $x=-4$, we can then merge them that yields $\left(-\dfrac{22}{3},\,-\dfrac{18}{7}\right)$.
Thanks everyone! Here is my solution: :D
Case 1: ($x\le -4$)
$x<-10$, $-\frac{22}{3}<x\le -4$
Case 2: ($-4 \le x \le 3$)
$-4\le x < -\frac{18}{7}$, $-\frac{10}{7}<x\le 3$
Case 3: ($x\ge 3$)
$x<-10$ => untrue statement, inadmissible
$x>-\frac{22}{3}$ => also not true
Therefore:
$(-\infty,-10) \cup (-\frac{22}{3},-\frac{18}{7}) \cup(-\frac{10}{7}, \infty)$
Correct :D?
Rido12 said:
Therefore:
Correct :D?
Yeap! You got them all correct! Well done!(Yes)
My prof deals with inequalities differently. Where you said :$x\le -4$, $-4\le x\le 3$, and $x\le 3$, he does it differently.
For example, case 2 is when we have $-4\le x\le 3$, where each are separate by a strict inequality. My prof likes to go back to the definition of the absolute value, namely, when $|x-a|>b$, we have when $x\ge a$ or when $x<a$. (Notice, he doesn't say $x\le a$. So in the context of our problem, he would say $x-3<0$ and $x+4\ge 0$. I have worked it out his way, and while you merged $(-22/3, -4]$ with $[-4, -18/7)$, he would have $(-22/3, -4)$ and $[-4, -18/7)$. So the strict inequality is missing from one of the -4's. Will these methods always be the same?
And we are allowed to say "$x\le -4$, $-4\le x\le 3$, and $x\le 3$" because we're not redefining the "function" because clearly those intervals would fail the vertical line test...we are only separating the critical numbers?
TL;DR:
If we are given an inequality, say $|x-3|>b$
Does it matter whether we separate the domain for when $x-3\ge 0$ and when $x-3\le 0$ versus when we separate the domain as $x-3 \ge 0$ and $x-3 <0$?
Rido12 said:
My prof deals with inequalities differently. Where you said :$x\le -4$, $-4\le x\le 3$, and $x\le 3$, he does it differently, in the context of our problem, he would say $x-3<0$ and $x+4\ge 0$.
Hi Rido12,
Ops...I'm sorry...your prof is absolutely right, I saw that my previous reply(#9) has some error in it, I should have explained it in the following manner for you, so that I would end up making error in defining the weak/strict inequality!:(It's like when we have $f(x)=2\left| x-3 \right|$, we can clear the absolute value sign by rewriting it piece-wisely:
$f(x)=\begin{cases}2(x-3), & x\ge 3, & \\[3pt] \\[3pt] -2(x-3), & x<3 \\ \end{cases}$
Also, when we have $g(x)=5\left| x+4 \right|$, it can be redefined as:
$g(x)=\begin{cases}5(x+4), & x\ge -4, & \\[3pt] \\[3pt] -5(x+4), & x<-4 \\ \end{cases}$
Let's say for now, our purpose is to study the difference of these two functions in the interval $x<3$ AND $x<-4$, which the resulting combined interval would be $x<-4$ and not $x\le -4$, like what I previously have told you...sorry!
Alright, thanks Anemone!
That makes sense :D But the answer is still the same, right?
Interval $(a,b)$ with $[b, c)$ merges to $(a,c)$? Since while one has an "open circle", the other closes that "circle"?
So would $x\le -4$, $-4\le x \le3$, and $x\ge 3$ be rewritten like: $x< -4$, $-4\le x <3$, and $x\ge 3$?
You're welcome, Rido12!
I'm so glad that you gave me chance to fix things right when I bungled the interval of the inequality. :eek:
Yes... yes and yes! :)
FAQ: Absolute value within absolute value
What is the absolute value within absolute value?
The absolute value within absolute value is a mathematical expression that involves taking the absolute value of an already absolute value. It is written as ||x||, where x is the initial value. This expression essentially means taking the absolute value of the absolute value.
How do you evaluate an expression with absolute value within absolute value?
To evaluate an expression with absolute value within absolute value, you first need to simplify the innermost absolute value expression. Then, you can simplify the outer absolute value expression using the simplified value from the inner expression. If there are multiple absolute value expressions nested within each other, you continue to simplify from the innermost expression outwards.
What are the properties of absolute value within absolute value?
The properties of absolute value within absolute value include:
  • The result is always a positive value.
  • It follows the same rules as regular absolute value, such as |-x| = |x|.
  • If there are multiple absolute value expressions nested within each other, the order of simplification does not matter.
In what situations would you encounter absolute value within absolute value?
Absolute value within absolute value can be encountered in various mathematical problems, such as solving equations with absolute value or finding the distance between two points on a number line.
What are some tips for simplifying expressions with absolute value within absolute value?
Some tips for simplifying expressions with absolute value within absolute value include:
  • Start by simplifying the innermost absolute value expression.
  • Remember that the result is always a positive value.
  • Use the properties of absolute value, such as the subtraction rule, to simplify the expression.
  • If there are multiple absolute value expressions nested within each other, work from the innermost expression outwards.
