Absolute Values in Separable Differential Equations
In summary, when solving a separable differential equation, the absolute values are removed by taking the exponential of both sides. This results in a new constant, c, which absorbs the ± from the absolute values. This is because the exponential is always positive.
patrickbotros
34
When solving a separable differential equation, my textbook says this:
ln|v-49|=-t/5+C→
|v-49|=e-t/5+C
v=49+ce-t/5
What happened to the absolute values? I think it has something to do with the exponential always being positive.
Mathematics news on Phys.org
ln|v-49|=-t/5+C→
|v-49|=e-t/5+C
v=49+ce-t/5
The equation ##\displaystyle\ |v-49|=e^{-t/5+C}\ ## is equivalent to
##\displaystyle\ v-49=\pm e^{-t/5+C}\ ## ##\displaystyle\ v-49=c\, e^{-t/5}\ ##, where ##\ c = \pm\ln(C) ##​
So the new constant, c, (lower case) absorbs the ± .
Ohhhh. HAHA!:oldlaugh: That was dumb :)
FAQ: Absolute Values in Separable Differential Equations
1. What is an absolute value in a separable differential equation?
An absolute value in a separable differential equation refers to the mathematical function that calculates the distance of a number from zero, regardless of its sign. It is represented by |x|, where x is the number being evaluated.
2. Why are absolute values important in separable differential equations?
Absolute values are important in separable differential equations because they help to eliminate the need for multiple solutions. By taking the absolute value of a variable, we can ensure that the solution of the equation is always positive, making the calculation and interpretation of results simpler.
3. How do you solve a separable differential equation with absolute values?
To solve a separable differential equation with absolute values, we first separate the variables on each side of the equation and then integrate both sides. When integrating, we must consider the absolute value of any constant terms that may arise. Once the integration is complete, we can solve for the constant of integration by considering different cases based on the value of the absolute value function.
4. Can you give an example of a separable differential equation with absolute values?
One example of a separable differential equation with absolute values is |y| = x + C, where C is the constant of integration. This equation can be solved by separating the variables, integrating both sides, and then considering different cases for the absolute value function to solve for C.
5. Are there any common mistakes made when dealing with absolute values in separable differential equations?
One common mistake when dealing with absolute values in separable differential equations is forgetting to consider different cases for the absolute value function when solving for the constant of integration. It is important to remember that the absolute value function can result in two possible solutions, depending on the value of the variable, and both must be considered when finding the solution to the differential equation.
