Absolute zero by definition is "nothing"
In summary, absolute zero is a temperature and not nothing. It is a mathematical limit that cannot be reached, only approached. At absolute zero, there is still some zero point energy present, so quantum fluctuations do not go away completely. The concept of temperature only applies to macroscopic systems, and a lone atom in its ground state does not have a temperature. Absolute zero is not possible to reach because the system cannot be treated as continuous for very small changes in energy.
GregoryC
Is absolute zero nothing? Can a quanta exist in nothing? There could be no quantum fluctuations at absolute zero.
Absolute zero is just the bottom end of our temperature scale. There is no direct relation of that to the presence, or absence, of anything. You could argue that the only way of achieving absolute zero is by removing everything (including space), but that's a rather moot consideration and probably not what you mean.
Yes, that is exactly what I am talking about. It is theoretical as is infinity.
Absolute zero is a temperature, not nothing. You can have matter at temperatures arbitrarily close to absolute zero. It doesn't become nothing. Absolute zero is a mathematical limit which cannot be reached, only approached. You still have some zero point energy at zero temperature, so it's not correct to say the quantum fluctuations go away.
Likes RJLiberator
Is anything nothing? Never.
Consider a lone atom with its electrons in their ground states. This is essentially what you're talking about. The atom doesn't somehow disappear just because it is in its lowest energy configuration. The only difference between a lone atom and macroscopic object is that the extra energy is partitioned into an enormous number of states and cannot be gotten rid of entirely.
Temperature only really makes sense for macroscopic systems. A lone atom has an energy, but not a temperature. That's because temperature is defined as a derivative:
$$\frac{1}{T} = \frac{\mathrm{d}S}{\mathrm{d}E}$$
The derivative doesn't really make sense on a microscopic scale because states are quantized. On a macroscopic scale, we smooth over the states, and treat the system as having a "density of states", such that the number of states varies smoothly with energy. Absolute zero is not possible to reach because you can't reasonably treat the system as continuous for very small changes in energy, and the mathematics are invalid.
Likes GregoryC and RJLiberator
Related to Absolute zero by definition is "nothing"
What is absolute zero?
Absolute zero is the lowest possible temperature that can be achieved, at which point all molecular motion stops.
Why is absolute zero considered "nothing"?
Because at absolute zero, there is no molecular motion, which means there is no energy or heat present. This is why it is often referred to as "nothing".
What is the value of absolute zero in degrees Celsius and Fahrenheit?
Absolute zero is equal to -273.15 degrees Celsius and -459.67 degrees Fahrenheit.
How was absolute zero discovered?
Absolute zero was first theorized by scientists in the 18th century, but it was not until the 19th century that it was experimentally proven by scientists such as Lord Kelvin.
What are some real-world applications of absolute zero?
Absolute zero is crucial in fields such as cryogenics and in the study of superconductors. It also helps us understand the behavior of gases under extreme conditions.
  • Other Physics Topics
  • Quantum Physics
