Absolute Zero or Uncertainty Principal?
In summary: It's not a solid theory until you can definitively say it can't be reached, and then work to prove that.
Dropabomb
A few weeks ago, I was wondering around my school when I realized that at absolute zero, Heisenburg's Uncertainty Principal may break down due to the non-existance of energy among subatomic particles. Later, while I was researching the topic, I found a few books that covered this topic and interpreted this as the evidence that absolute zero can not be reached since under no circumstances should HUP break down. However, an article published by the NewScientist magazine stated that "Even if the universe itself froze over and its temperature plunged to absolute zero, zero-point vibrations would still be going strong, propelled by energy from empty space." Which contradicts my previous statements. So, can anyone tell me which statement is more accurate. If neither statements are at all accurate, can someone provide me with a more accurate picture regarding this topic?
Look into a QM text at a quantum harmonic oscillator. Is the lowest possible energy zero, or is it a finite, non-zero value?
Furthermore, the specific heat of nobel gasses, for example, exhibit the deBoer effect in which the zero-point energy correction kicks in.
These two contradict your guess.
Zz.
Your first statement "at absolute zero, Heisenburg's Uncertainty Principal may break down due to the non-existance of energy among subatomic particles. " is wrong; it works the other way- because of Heisenburg's uncertainty principle you cannot have "non-existance of energy" and so particles do not stop at "absolute zero". The other two statements, that absolute zero cannot be reached and that even at absolute zero there is still zero-point vibrations are not contradictory, they are just different ways of saying the same thing. The first interprets "absolute zero" as meaning no motion and so it is impossible to reach absolute zero. The other interprets "absolute zero" as the lowest possible temperature and so says that at absolute zero there is still motion.
Oh
Oh, I see, thanks for the clarification.
If this stasement was correct, I would be without a job! You ment to say INFINITE, didn't you?
sam
samalkhaiat said:
sam
No, I meant "finite" and non-zero. Why would it be infinite? The lowest eigen energy of a quantum SHO is [itex]1/2 \hbar\omega[/itex]. This is certianly not "infinite".
Zz.
ZapperZ said:
Yeh, you are right. I just noticed that you were talking about single SHO.
When I talk about "absolute zero", I use infinite sum of SHO?
regards
sam
As I understand it it's hypothetical but supported by theory, which is somewhat unusual, but not in physics,we assume that these things cannot be reached, but we have no idea why exactly, and we can make suppositions based on this, regardless of the fact that there is no evidence. Essentially we assume, we have no real idea, so we take assumption as fact sometimes, because our actual knowledge is lacking. As always this is a suposition, if you can prove that we cannot reach absolute zero absolutely, do so.:smile:
Personally I don't get it, it seems counter intuitive to make bold that it cannot be reached. Often the case, someone comes up with an idea it's right, without any regard for logic.
At absolute zero a system is in its lowest possible energy state. That state need not be zero.
juju
Related to Absolute Zero or Uncertainty Principal?
1. What is absolute zero?
Absolute zero is the lowest possible temperature that can be achieved, at which point all molecular motion stops. It is equivalent to 0 Kelvin or -273.15 degrees Celsius.
2. How was absolute zero discovered?
The concept of absolute zero was first proposed by scientists in the early 1700s, but it was not until the 19th century that it was experimentally confirmed by scientists such as Lord Kelvin and James Joule.
3. What are the effects of reaching absolute zero?
Reaching absolute zero has many interesting effects, including changes in material properties such as electrical resistance and thermal conductivity. It also allows scientists to study quantum phenomena, as particles behave differently at extremely low temperatures.
4. What is the uncertainty principle?
The uncertainty principle, also known as Heisenberg's uncertainty principle, states that it is impossible to simultaneously know the exact position and momentum of a particle. This means that there is a fundamental limit to our ability to measure and predict the behavior of particles at a quantum level.
5. How does the uncertainty principle relate to absolute zero?
The uncertainty principle is closely related to absolute zero because at absolute zero, particles have minimal energy and therefore their position and momentum become more uncertain. This makes it difficult to measure and predict their behavior, and why reaching absolute zero is necessary for studying quantum phenomena.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Optics
12K
  • Other Physics Topics
  • Quantum Physics
