Absorption and Spectroscopy: Why increased counts at lower energies?
In summary, the gamma ray emission lines can be used to determine the absorption coefficients of different radioactive materials. The peak at about 100 MeV decreases with the addition of material to the photomultiplier, but the peaks before channel 50 increase with material thickness. It is still unknown what is causing this, but it is something that we are looking into.
lamadwp
Hi!
In my lab class, we are using a photomultiplier to examine gamma ray emission lines and determine absorption coefficients of different radioactive materials.
As we test for absorption (by layering on metals, incrementally increasing the thickness), we consider spectral graphs. We compare each subsequent graph (one from each thickness increment) to that of the nucleus without any absorption material and notice that, while the peaks we are following (they are the decay energies, eg. for Barium, we followed energy 0.356 MeV) are decreasing (the height of the peak is determined by the number of counts recorded by the photomultiplier) with increased metal thickness, other peaks are increasing in count.
We want to know what is causing the increase in lower-energy readings.
We also want to understand all the spectral features of the graphs as we are very unsure of any peaks outside the given decay energies..
{see attachment for graph} Each Series in the legend denotes an increase in absorber thickness of about 6mm.
Not indicated on the graph is that we followed the peak at about 100 on the x-axis (it's not actually 100 MeV or anything--the program we used filtered energies into channel bins, which we calibrated. The indicated energy here is 0.356 MeV). We attribute its decrease to absorption of the gamma rays as we added more material between our source and the detector. However, the peaks before channel 50 increase with material thickness. This is what we are trying to figure out.
We are considering Compton scattering, elastic scattering, and photoelectric absorption, but are unsure as to where these are applicable.
6mm should be sufficent to block any secondary electrons which do not come from the last absorber plate, Compton electrons should decrease with increasing absorber thickness. Series 2 is with one absorber plate?
Photons, emitted from secondary electrons?
Radioactivity from the plates? Did you check the results without the source?
Yes, Series 2 is with the first plate of lead (~6mm), Series 3 is with about 12mm of lead shielding, etc. Series 1 is the source without any shielding.
We did not check the plates without the source :T
Thanks for the information about Compton electrons--I'll look it up some more, but might you be able to explain why those counts decrease with thickness, too?
More absorbing plates -> more photons get absorbed.
That is an exponential decay.
Maybe the peaks below channel 50 are the K-alpha and K-beta characteristic x-rays of lead. If you know the energies corresponding to the channels, you could compare them to the known x-ray energies for lead.
Also see here for some sample gamma spectra that show x-ray peaks from lead.
Thank you!
Thank you for your responses, everyone!
TSny, those resources were incredibly helpful, thank you!
Related to Absorption and Spectroscopy: Why increased counts at lower energies?
1. What is absorption spectroscopy?
Absorption spectroscopy is a technique used to measure the amount of light absorbed by a substance as a function of wavelength or frequency. It is commonly used in chemistry, physics, and astronomy to study the properties of materials and the composition of celestial objects.
2. What causes increased counts at lower energies in absorption spectroscopy?
Increased counts at lower energies in absorption spectroscopy can be caused by several factors, including the presence of low energy transitions in the sample, the use of a detector with low energy resolution, and the presence of impurities or contaminants in the sample.
3. How does absorption spectroscopy work?
Absorption spectroscopy works by passing a beam of light through a sample and measuring the amount of light that is absorbed by the sample. The amount of absorption is then compared to a reference sample to determine the absorption spectrum of the sample.
4. What is the relationship between absorption and energy in spectroscopy?
The relationship between absorption and energy in spectroscopy is known as the absorption spectrum. The spectrum shows the amount of light absorbed by a substance at different energies, which can provide information about the electronic and molecular structure of the substance.
5. Why is absorption spectroscopy important in scientific research?
Absorption spectroscopy is important in scientific research because it allows scientists to study the properties and composition of a wide range of materials, including gases, liquids, and solids. It is a non-destructive technique, meaning that the sample does not need to be altered or destroyed in order to obtain information about its properties. This makes it a valuable tool in many fields of science, including chemistry, physics, astronomy, and environmental science.
