Absorption of a photon by atom - where does the energy go?
In summary, the conversation discusses the effects of a photon hitting a hydrogen-like atom with a transition energy of \omega. It is noted that by conservation of momentum, the atom will receive a momentum kick \vec{k} and a change in internal energy of \omega. This leads to a discussion of the use of off-resonant light to induce transitions and the frame-dependence of kinetic energy. The suggestion is made to work the problem in the center-of-momentum frame and then transform to the frame in which the atom is at rest, where the frequency and energy of the photon will be slightly different. It is mentioned that Mössbauer spectroscopy can avoid the recoil energy difference in energy levels.
wotanub
230
I recently thought about this. Let's say there's a hydrogen-like atom with a transition energy [itex]\omega[/itex]. If it is hit with a photon of frequency [itex]\omega[/itex], it will make a transition to the excited state, so the change in internal energy is [itex]\omega[/itex]. But by conservation of momentum, the atom will also receive a momentum kick [itex]\vec{k}[/itex], causing a change in kinetic energy as perceived from the lab frame if we initially take the atom to be at rest in that frame.
So does some of the energy become the kinetic and some the internal? Does that mean we actually use off-resonant light to induce transitions since some of the energy will go into the kinetic?
Pretty sure this is simple and has to do with kinetic energy being frame dependent? In the center-of-mass frame, there is never any kinetic energy since there is only one massive body...
Try working the problem in the center-of-momentum frame, not the center-of-mass frame - the photon does have momentum.
Once you've done that you can transform to the frame in which the atom is at rest. In that frame the frequency and the energy of the photon will be slightly different.
Yes, energy levels with/without recoil will be different. Mössbauer spectroscopy can avoid the recoil energy.
Related to Absorption of a photon by atom - where does the energy go?
1. What happens to the energy of a photon when it is absorbed by an atom?
When a photon is absorbed by an atom, its energy is transferred to the atom's electrons. This causes the electrons to become excited and move to a higher energy level.
2. Does the energy of the photon disappear after being absorbed?
No, the energy of the photon does not disappear. It is simply converted into the energy of the excited electrons.
3. How does the absorption of a photon affect the atom's behavior?
The absorption of a photon can cause the atom to undergo chemical reactions, emit light, or transfer energy to neighboring atoms.
4. Can an atom absorb more than one photon at a time?
Yes, an atom can absorb multiple photons at a time, as long as the combined energy of the photons does not exceed the energy needed to excite the electrons to the next energy level.
5. What happens if an atom absorbs a photon with energy higher than the energy needed to excite its electrons?
If an atom absorbs a photon with excess energy, the excess energy is either released as a new photon or transferred to the surrounding environment. This process is known as fluorescence or phosphorescence, respectively.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Atomic and Condensed Matter
  • Quantum Physics
