Abstract Alg. - maximal ideals in Z[x]
  • Thread starter WannaBe22
  • Tags
    Abstract
In summary, the person is trying to find a way to solve a homework equation where they are stuck. They have tried one obvious way and that didn't work. They have also tried asking for guidance and that has been helpful. They are looking for a way to solve equation (p,f(x)) where f(x) is a polynomial that is irreducible in Zp. If they can prove that every ideal in Z[x] generated by (p,f(x)) where f(x) is a polynomial that is irreducible in Zp is maximal, then (p,f(x)) is maximal.
WannaBe22
76
Can someone tell me how can I prove that every ideal in Z[x] generated by (p,f(x)) where f(x) is a polynomial that is irreducible in Zp is maximal??
Thanks!
What have you tried?
I assume you've tried at least one obvious way to get started? Where did you get stuck?
Also, how many ways can you fill in the blank in the following sentence?
If I can prove ______, then (p, f(x)) is maximal​
One answer might suggest to you a line of attack...
Well..There are 2 possible ways:
1. If I can prove that Z[x]/I where I=(p,f(x)) is a field, then (p,f(x)) is maximal...
2. If I can prove that if I is contained in an ideal J that is contained in Z[x] then J=I or J=Z[x] thjen (p,f(x)) is maximal...
The first way doesn't help me at all... It seems like the second way is the one we need to use... But I can't figure out what is the contradiction we get by assuming that there is an element k that exists in J but not in I...How does it help us?
I'll be glad to receive some guidance around here...
THanks a lot
That's a shame -- it's the way I would have done it, but the method I had in mind requires knowledge of finite fields.
Maybe restating it more algebraically would help? For some other element a, You're looking to show the existence of a linear combination (coefficients in Z[x])
ua + vp + wf = 1​
When talking about the element "1" , you mean the unit element of Z[x] right? It doesn't have to be 1 ...
Hmmmm When adding up an element a such as a isn't in (p,f(x)) , that means that:
gcd(p,f(x),a)=1 so we have u,v,w such as ua+vp+wf=Unit element of Z[x]...
Am I right?
If you'll be able to verify my answer it will be great... Afterwards I'll be delighted if you'll be able to answer the folowing questions:
1. Let's take p=5, f(x)=x^3+x+1, a=2 ...
By the statement above, in the ideal that contains a,p and f(x) there are all the polynomials over Z... But how can we create x^2+1 for example by linear combinations of the 3?
2. What is the unit element in Z[x]? If it's the same as the one in Z, So how come it "spans" the whole ring? I mean, if 1 is the unit element in Z[x], so how can we produce every element in Z[x] by multiplications of 1?
Thanks a lot man!
The coefficients of linear combinations come from the ring. So, the element f(x) can be produced by f(x) * 1.
Well, so how can we show that ua + vp + wf = 1 ?
Well, you brought up GCD's. What can you tell me about those? (You may need to break into cases on what kind of element a is)
Well...If we take an element "a" that is not in (p,f(x)) ... That means that we can't produce this element by final sums of p & f(x) ...I don't that the gcd of p,f(x)&a must be 1... I'm not even sure if gcd(p,f(x)) must be 1... We only know that f(x) has no roots in Zp, I don't think that their gcd must be 1...
Can you give me a more detailed guidance please?
I become pretty desperate...
Thanks
FAQ: Abstract Alg. - maximal ideals in Z[x]
What is Abstract Algebra?
Abstract Algebra is a branch of mathematics that studies algebraic structures such as groups, rings, and fields. It is concerned with the properties and relationships between these structures and their operations.
What are maximal ideals?
Maximal ideals are special types of ideals in a ring that cannot be properly contained in any other ideal. In other words, they are the largest possible ideals in a given ring.
What is the significance of maximal ideals in Abstract Algebra?
Maximal ideals play an important role in the structure and properties of rings. They are used to define quotient rings, which are important in understanding the structure of a ring and its ideals.
How are maximal ideals identified in Z[x]?
In the polynomial ring Z[x], maximal ideals are identified by the leading coefficient of the polynomial. Specifically, an ideal generated by a polynomial with a prime leading coefficient is a maximal ideal in Z[x].
What are some applications of maximal ideals in Z[x]?
Maximal ideals in Z[x] have various applications in number theory, algebraic geometry, and cryptography. They are also important in studying polynomial rings over other fields and their properties.
