Abstract Algebra: Isomorphic polynomial rings
In summary, the homework statement states that if F is an infinate field, then the polynomial ring F[x] is isomorphic to the ring T of all polynomial functions from F to F. The attempt at a solution states that T is isomorphic to F[x], but injective. The conclusion is that F[x] is isomorphic to the ring T.
katarinab316
If F is an infinate field, prove that the polynomial ring F[x] is isomorphic to the ring T of all polynomial functions from F to F
f(a+b) = f(a) + f(b)
f(ab)=f(a)f(b)
It is surjective by the definition of T
Injective: If f is not equal to g in F[x], then f(x) is not equal to g(x) in T.
Let h=f-g and assume h is not 0 in F
Claim: h(x) is not equal to zero in T, then h(a)=0 for every a in F. Thus every a in F is a root of the polynomial h in F[x}. However, there is no nonzero polynomial with infinately many roots, thus h=0 in F, which contradicts the asumption of h is not 0 in F, so injective. So F[x] is isomorphic to the ring T.
Hrm. You haven't said what you want from us. I assume just to review your work?
f(ab)=f(a)f(b)
This doesn't make sense. Why are you starting with the thing you're trying to prove? What is f? a? b? What was the point of those equalities? Why are they true? What is surjective? (I assume some of these latter questions, as well as what follows, would become clearer after you answer the first few)
Well basically this is an assignment turned in that got a "redo". As you can probably tell, I'm so confused in this subject I don't even know how to begin to correct it...thanks for the input so far
FAQ: Abstract Algebra: Isomorphic polynomial rings
What is abstract algebra?
Abstract algebra is a branch of mathematics that studies algebraic structures such as groups, rings, and fields. It deals with the properties and operations of these structures, rather than focusing on specific numbers or equations.
What are isomorphic polynomial rings?
Isomorphic polynomial rings are rings that have the same underlying structure and operations, but may differ in the names or symbols used for the elements and operations. In other words, they are structurally identical but may have different notations.
What is the significance of isomorphism in abstract algebra?
Isomorphism is important in abstract algebra because it allows us to study different algebraic structures that have the same underlying structure. This allows us to make connections and draw conclusions about these structures, and it also helps to simplify and generalize complex concepts.
How do you determine if two polynomial rings are isomorphic?
To determine if two polynomial rings are isomorphic, we need to show that there exists a bijective ring homomorphism between them. This means that there is a function between the two rings that preserves the operations and structure, and is both one-to-one and onto.
What are some real-world applications of isomorphic polynomial rings?
Isomorphic polynomial rings have many applications in computer science, coding theory, and cryptography. They are also used in physics and engineering to study symmetry and conservation laws. Additionally, isomorphism can help to identify patterns and relationships between seemingly different mathematical structures.
