AC circuit: is the voltage source absorbing or delivering?
In summary, the conversation discusses analyzing an AC circuit with a voltage source, resistor, and inductor. The goal is to find the power in each element and determine if it is absorbing or delivering. The current is found to be 21 ∠93° Amps and the voltages on the left and right are 240√2∠60° and 280√2∠30°, respectively. The resistor is 5Ω and the inductor is J8Ω. The concept of superposition is mentioned and the direction of the current is important in determining if a source is producing or consuming power. The conversation also mentions using exponential notation and finding the complex power for each source to determine if it is
mrhingle
I'm looking at an AC circuit. There is a voltage source, a resistor, an inductor, then another voltage source. One loop. I am supposed to find the power in each element and tell weather it is absorbing or delivering. I think I remember that when a current goes into the negative terminal of a voltage source, the source is delivering, and in an AC circuit the current goes back and forth. I found the current to be 21 ∠93° Amps. The voltage on the left is 240√2∠60°, and the one on the right is 280√2∠30°. Both have negative terminals at the ground. The resistor is 5Ω, and the inductor is J8Ω. Do I need to use superposition. Can I find the power with the total current that I found using mesh? What's happening here?
Why the √2's in the voltage descriptions? Are you converting from RMS to peak? If you're dealing with power you should leave things as RMS, or convert to RMS if peak values are given.
You've remembered correctly regarding how to determine if a source is delivering (sourcing) or consuming (sinking) power.
You can use superposition if you wish. But it looks like you've already determined the net current. What is the the assumed direction direction of your current? Do you know how to determine the complex power associated with a voltage source given the current out of the + terminal (same as into the - terminal)? The real component of the complex power is the real power.
I assume the book used square root of 2's to make for easy transfer to RMS. I am given Peak, and plan to convert to RMS. To find the current I assumed clockwise around the mesh.
Complex power = 1/2 VI*. Never considered direction of current when looking at it. Pretty new concept to me. So how do I use the assumed direction of current to know if the voltage source is absorbing or delivering?
Okay, so drop the square roots from the peak values at the outset. Then the complex power for the source will be just VI*. With the assumed clockwise direction for the current, the complex power produced by the first source is V1I*. Do the math and take a look at the sign of real component. If it's positive, the source is producing power. If it's negative, it's consuming power. Same goes for the second source, only here the assumed current direction is flowing INTO the source's + terminal. So V2I* yields the power consumed. If the sign of the real term is negative, it's "consuming" a negative amount of power, i.e., it's producing power.
Likes 1 person
I would proceed as follows:
Without loss of generality, make V1 angle = pi/6, then V2 angle = 0. V1 on left, V2 on right.
Compute complex I. Using superposition is a good idea.
Compute I*, the complex conjugate of I. Also compute complex conj. of V1. You already have complex conj. of V2 of course.
Then compute P1 = 1/2 (V1 I* + V1* I) and P2 = 1/2 (V2 I* + V2* I).
Either source will be generating real power if its P is +, and will be absorbing real power if its P is -.
Hints:
1. Use exponential notation thruout, including Z.
2. [exp(j theta)]* = exp(-j theta).
Related to AC circuit: is the voltage source absorbing or delivering?
1. Is the voltage source absorbing or delivering energy in an AC circuit?
In an AC circuit, the voltage source can either be absorbing or delivering energy, depending on the direction of current flow. If the current flows from the source towards the load, the voltage source is delivering energy. If the current flows from the load towards the source, the voltage source is absorbing energy.
2. How can I determine if the voltage source is absorbing or delivering energy in an AC circuit?
To determine if the voltage source is absorbing or delivering energy, you can use the passive sign convention. This convention states that if the current enters the positive terminal of the voltage source, it is delivering energy. If the current enters the negative terminal, the source is absorbing energy.
3. What is the difference between an AC voltage source and a DC voltage source?
The main difference between an AC voltage source and a DC voltage source is the direction of current flow. In an AC circuit, the current alternates direction, while in a DC circuit, the current flows in one direction. Additionally, AC voltage sources are usually sinusoidal, while DC voltage sources are constant.
4. Can an AC voltage source be used to power DC devices?
Yes, an AC voltage source can be used to power DC devices by using a rectifier. A rectifier is a circuit that converts AC voltage to DC voltage by allowing current to flow in one direction only. This is commonly used in household electronics such as laptops and phone chargers.
5. How does the voltage source affect the behavior of an AC circuit?
The voltage source is responsible for supplying the energy to the circuit and maintaining a constant voltage level. It also determines the direction of current flow and can affect the overall performance of the circuit. Without a voltage source, an AC circuit would not be able to function.
