AC-Coupled Current Input to Amplifier
In summary: I tried the instrument's high pass filter function, but it didn't seem to do much to get rid of the DC offset.I tried the instrument's high pass filter function, but it didn't seem to do much to get rid of the DC offset.The DC offset is a constant 6 orders of magnitude less than the bias current.
PhysicsGuy99
Hello all,
I am looking for a means of AC-coupling a current input to an amplifier http://www.thinksrs.com/products/SR570.htm . I found some methods to do this with a simple op amp set-up, but I am not sure how to accomplish this with this instrument. The reason I want to remove the DC current component is because I am trying to measure a very small (~6 orders of magnitude smaller) AC signal riding on the DC signal. The instrument does allow for a 0 to +_5 mA offset, but this is not a large enough range for my application. It seems that there is a potentially simple solution to this problem that I am overlooking.
Any insights would be much appreciated!
Thanks,
Alex
Is there any reason why you cannot simply use a DC blocking capacitor? Frequency too low? Phase shift too great?
How about a transformer?
I think I can use a dc-blocking capacitor, but from my readings I believe it is not just as simple as putting a capacitor in series with the signal. It seems that I need a sink for the dc component of the signal, but I am not sure how that all works, particularly because I am using a "black-box" amplifier. I know the input resistance for various gain settings, and there is a simplified circuit diagram in the user manual I provided above.
You need a return path for the DC component - that makes sense. A large inductor across the input would provide that DC path while presenting a high(er) impedance to the AC signal. I guess it depends on the size of the DC component and the frequency of the (wanted) AC signal. A signal transformer might also work, as suggested above. You could also use a precision current source to subtract the DC current. One advantage of the current source is that there are no phase shifts to worry about.
AC coupling implies a high-pass filter with a specified cut-off frequency. What is the cut-off frequency you require?
The SR570 has a “variable input offset current” adjustment. How much offset do you require?
If you null the input current before a series of measurements you will have eliminated the initial offset current.
Is the DC offset constant in time to 6 orders of magnitude?
Can you sample the signal with a 32 bit ADC, then remove the offset digitally?
If the wanted signal is 6 orders of magnitude smaller than the bias current then any offset bias may need to be accurate to 6 orders of magnitude.
An alternative is to connect a big inductance across the current meter. That will act as a DC pass while the small changing AC signal is measured. The inductor will need to be screened to prevent it picking up stray noise. You may need a low-leakage flyback-diode across that inductor. You may also need to compensate for the series resistance of the inductor with the adjustable offset voltage of the meter.
The value of inductance required comes down to impedance and the bandwidth you need.
The input current I require is order of 10-100mA. Well outside the range of the preamp. I am going to try just placing a capacitor in series with the signal and see if that does the trick.
You would do better connecting a big inductor across the meter terminals.
The problem with just capacitively coupling is that the current source will saturate trying to produce the dc current.
Can you give a little insight with regard to the frequency range of the DC (you said it varied), and the frequency range of the recovered signal.
Have you tried the instrument's high pass filter function (That's a dc blocking filter, isn't it?)
Or, is that filter too far down the chain to not saturate from the DC component?
Related to AC-Coupled Current Input to Amplifier
What is AC-coupled current input to amplifier?
AC-coupled current input to amplifier is a method of transferring an alternating current (AC) signal to an amplifier for amplification. It involves using a capacitor to block the DC component of the signal, allowing only the AC component to pass through to the amplifier.
Why is AC-coupling used in amplifier circuits?
AC-coupling is used in amplifier circuits to block any DC offset or bias voltage that may be present in the input signal. This ensures that the amplifier only amplifies the AC component of the signal, resulting in a more accurate and distortion-free output.
How does AC-coupled current input affect the frequency response of an amplifier?
AC-coupling can affect the frequency response of an amplifier by causing a high-pass filter effect. The capacitor used in AC-coupling has a reactance that decreases with increasing frequency, which can result in a decrease in the overall gain of the amplifier at high frequencies.
What are the advantages of using AC-coupled current input in amplifier circuits?
AC-coupled current input offers several advantages, including the ability to block DC offset, improved accuracy and linearity, and the ability to use a single-ended power supply for the amplifier. It also allows for the use of coupling capacitors, which can help protect the amplifier from high voltage transients.
Are there any limitations to using AC-coupled current input in amplifier circuits?
One limitation of using AC-coupled current input is that it can introduce phase shift in the signal, especially at lower frequencies. This can affect the accuracy and fidelity of the output signal. Additionally, the capacitor used in AC-coupling can introduce noise and distortion to the signal, so careful selection and placement of the capacitor is important.
  • Electrical Engineering
