MHB AC Method for Factoring Trinomials
The method for factoring a trinomial of the form ax² + bx + c involves rewriting it as a product of two binomials, (fx + u)(gx + v). It begins by identifying factor pairs of the product ac that sum to b, denoted as s and t, leading to the form (ax + s)(ax + t). The coefficients are then simplified by dividing out their greatest common factors. The method is validated through a proof that confirms the resulting expression matches the original quadratic. This approach ensures accurate factorization, provided the trinomial has no common factors among a, b, and c.
Ackbach
MHB
Description of the Method
We are given a trinomial of the form $ax^{2}+bx+c$, and asked to factor it into a product of two dissimilar binomials $(fx+u)(gx+v)$. The method that follows assumes $a,b,c$ have no common factor; if they do, you must factor out the greatest common factor before proceeding.
The method is as follows:
  • Write $ax^{2}+bx+c$ as $(ax+\underline{\phantom{45}}\,)(ax+\underline{\phantom{45}}\,)$.
  • Examine the factor pairs of the product $ac$, and see which pair, when added together, make $b$. Call this pair $s,t$. You now write $(ax+s)(ax+t)$.
  • For each binomial, divide out the greatest common factor of the coefficients. That is, for $ax+s$, divide out the greatest common factor of $a$ and $s$, and for $ax+t$, divide out the greatest common factor of $a$ and $t$.
  • The result is $(fx+u)(gx+v)$, where
    \begin{align*}
    f&=\frac{a}{\text{gcf}(a,s)} \\
    u&=\frac{s}{\text{gcf}(a,s)} \\
    g&=\frac{a}{\text{gcf}(a,t)} \\
    v&=\frac{t}{\text{gcf}(a,t)}.
    \end{align*}
Examples of the Method
  • Factor $15x^{2}+29x-14$. There is no gcf, so we examine the product $15\times (-14)=-210$. The pair products of $-210$ that add to $29$ are $35$ and $-6$. Hence, we write
    $$15x^{2}+29x-14=\left(\frac{15x+35}{5}\right)\left(\frac{15x-6}{3}\right)=(3x+7)(5x-2).$$
  • Factor $12x^{2}-46x-36$. This one has a greatest common factor, so we get that out of the way as $2(6x^{2}-23x-18)$. The pair products of $6(-18)=-108$ that add to $-23$ are $-27$ and $4$. So we write
    $$2(6x^{2}-23x-18)=2\left(\frac{6x-27}{3}\right)\left(\frac{6x+4}{2}\right)=2(2x-9)(3x+2).$$
Note that you can use the prime factorization of $ac$ to find all factor pairs, and hence the correct factor pair. Also note that if $ac<0$, you are looking for the difference between the two factors of the factor pair, and if $ac>0$, you are looking for the sum.
Proof of the Method
We assume that it is possible to execute the method. If the method does not execute, then I claim the quadratic does not factor. First, we show that multiplying out the result yields the original quadratic. That is,
\begin{align*}
(fx+u)(gx+v)&=fgx^2+fvx+ugx+uv \\
&=fgx^2+(fv+ug)x+uv \\
&=\left(\frac{a}{\text{gcf}(a,s)}\cdot \frac{a}{\text{gcf}(a,t)}\right)x^2
+\left(\frac{a}{\text{gcf}(a,s)}\cdot\frac{t}{\text{gcf}(a,t)}+
\frac{s}{\text{gcf}(a,s)}\cdot \frac{a}{\text{gcf}(a,t)} \right)x \\
&\qquad+\frac{s}{\text{gcf}(a,s)}\cdot \frac{t}{\text{gcf}(a,t)} \\
&=\left(\frac{a^2}{\text{gcf}(a,s)\cdot \text{gcf}(a,t)}\right)x^2
+\left(\frac{a(s+t)}{\text{gcf}(a,s)\cdot\text{gcf}(a,t)}\right)x
+\frac{st}{\text{gcf}(a,s)\cdot\text{gcf}(a,t)} \\
+\left(\frac{ab}{\text{gcf}(a,s)\cdot\text{gcf}(a,t)}\right)x
+\frac{ac}{\text{gcf}(a,s)\cdot\text{gcf}(a,t)} \\
&=\frac{a}{\text{gcf}(a,s)\cdot\text{gcf}(a,t)} \, (ax^2+bx+c).
\end{align*}
Recall that $st=ac$, and $s+t=b$. So, for this method to work, we must show that
$$\frac{a}{\text{gcf}(a,s)\cdot\text{gcf}(a,t)}=1.$$
By the Fundamental Theorem of Arithmetic, we can write
\begin{align*}
a&=p_1^{a_1}\cdot p_2^{a_2}\cdots p_k^{a_k} \\
b&=p_1^{b_1}\cdot p_2^{b_2}\cdots p_k^{b_k} \\
c&=p_1^{c_1}\cdot p_2^{c_2}\cdots p_k^{c_k},
\end{align*}
where the $p_j$ are primes, and $a_j, b_j$ and $c_j$ are non-negative integers. Note that we have included all primes in either $a$ or $b$ or $c$'s factorization, and recall that $\text{gcf}(a,b,c)=1$. This forces $\min(a_j,b_j,c_j)=0$ for all $j$. Next, suppose that
\begin{align*}
s&=p_1^{s_1}\cdot p_2^{s_2}\cdots p_k^{s_k} \\
t&=p_1^{t_1}\cdot p_2^{t_2}\cdots p_k^{t_k},
\end{align*}
are the prime factorizations of $s$ and $t$. Because $ac=st$, it must be that $a_j+c_j=s_j+t_j.$ Then
\begin{align*}
\text{gcf}(a,s)&=p_1^{\min(a_1,s_1)}\cdot p_2^{\min(a_2,s_2)} \cdots
p_k^{\min(a_k,s_k)} \\
\text{gcf}(a,t)&=p_1^{\min(a_1,t_1)}\cdot p_2^{\min(a_2,t_2)}
\cdots p_k^{\min(a_k,t_k)}.
\end{align*}
We are attempting to prove that
$$a=\text{gcf}(a,s)\cdot\text{gcf}(a,t),$$
or, equivalently, that
$$a_j=\min(a_j,s_j)+\min(a_j,t_j)$$
for all $j$. This equation is certainly not true in general; however, I argue that it is true in our special case here.
We examine the equation $s+t=b$. Let $z=\text{gcf}(s,t)$. Then $z|b$. But if $z>1$, then $z$ cannot divide both $a$ and $c$, or else $\text{gcf}(a,b,c)=z>1$. Then
$$\text{gcf}(a,b,c)=1\implies \text{gcf}(a,s+t,c)=1\implies
\text{gcf}(a,c,s,t)=1\implies \min(a_j,c_j,s_j,t_j)=0.$$
We break this down by cases.
  • Suppose $c_j=0$. Then $a_j=s_j+t_j$, implying that $a_j>s_j$ and $a_j>t_j$. Hence, $\min(a_j,s_j)+\min(a_j,t_j)=s_j+t_j=a_j,$ as required.
  • Suppose $c_j>0$. Then we have two subcases:
    • $a_j=0$. Then $\min(a_j,s_j)+\min(a_j,t_j)=0+0=0=a_j$, as required.
    • $a_j>0$. Then either $s_j$ or $t_j$ is zero. Without Loss of Generality, we may assume $s_j=0$. Then $a_j+c_j=t_j$, implying $a_j<t_j$. It follows that $\min(a_j,s_j)+\min(a_j,t_j)=0+a_j=a_j$, as required.
In all cases, $\min(a_j,s_j)+\min(a_j,t_j)=a_j$, showing that the method, if it's possible to execute, does indeed result in a final expression that is
equivalent to the original expression.
By the Fundamental Theorem of Algebra, if the quadratic factors, it factors uniquely. Since we have found a factorization, assuming it has worked, we have found the correct factorization.
Science news on Phys.org
Greg Bernhardt said:
Thanks @Ackbach! What forum do you think we could move this to?
STEM Educators and Teachers again, I think.
