AC Signals - Radians and Degrees? Why do we use both?
In summary: Flies ?In summary, electrical engineers represent sinusoidal signals with the frequency in terms of radians/sec but phase shift in terms of degrees. The convention originated from when people used Hertz units to measure frequencies. Most EE I know use Hz, not radians/sec to represent frequencies. Using Hz is fine for general chat about frequency but, once you get into Oscillations and Calculus, you will get into a real muddle with 2π turning up every time you integrate or differential. Angular frequency (ω) makes life so much easier. V=V0cos(ωt -kx) is much easier to manipulate than V=V0cos
tomizzo
114
Why exactly do electrical engineers represent sinusoidal signals with the frequency in terms of radians/sec but phase shift in terms of degrees? Why don't we represent the phase shift in radians?
I'm curious where/why this convention originated.
Most EE I know use Hertz, not radians/sec to represent frequencies ... :smile:
I'm curious to know where you got this idea since I agree w/ BvU that EE's use HZ. In fact, in my 50 years as an EE I can't remember anyone using radians/sec for frequency and if anyone had, I would really have had to scratch my head to figure out what he was talking about.
EDIT: I should add that I'm talking about in conversation. In some calculations, radians/sec might be used but it would be odd to express a final result, in conversation, with those units.
V=V0cos(2πft - kx)
If you don't like the Maths then fair enough but twenty million flies can't be wrong.
Flies ?
V=V0cos(2πft - kx)
its a scalar. You can do the math any way you'd like and it won't make much of a difference, just 2 extra presses of the keyboard.
At the end of the day, when people review your findings, most would prefer it in Hz.
If you present the data in rad/s and they can't understand it, they probably should be reviewing your findings anyways.
We use radians/second for angular frequency. For example, 60 hertz is 377 radians per second.
When doing simulations or solving integrals, if we want the result of an integral to be in units of radians, then the integrand (frequency difference) is best expressed in radians per second. Of course you can always integrate frequency differences in hertz. The result will be expressed in fractions of a cycle, which could then be converted to radians. Same math, just awkward experessions.
BvU said:
Flies ?
"Eat poo - twenty million flies can't be wrong" (Ancient philosopher)
Likes phinds
Yep.
In my opinion, since w*t it is an angle[radians] w=rad/sec it is not a “frequency” but an “angular velocity”.
However ,I think, we are speaking about frequency ["f"] from the expression 2*pi*f and “f” will
stay here Hz [or cycle/sec].:wink:
The phase angle shifting is connected with connection shifting symbol representing an hour on a 12 hours clock.
Here for each 30 degrees one has to add an hour. It will be inconvenient to use here radians -in my opinion.:smile:
The angular frequency is w=2*Pi*f - and there are some people using the unit Hertz for this expression. However, this is WRONG.
The frequency f is given in Hz and the angular frequency w must be given in rad/s.
And there any many good reasons for using w rather than f.
For example, what is the impedance of a capacitor? Right - it is 1/wC.
That seems valid to me but why would you want to change an established term? If we all know what it means there is no confusion.
Yes, the frequency in Cycles pre Second (Hz) is more readily appreciated and very commonly used in practical measurements. However, in theoretical descriptions - like, for instance, this, the elegance and symmetry of the form of the equation and the pattern that is revealed, using ω, speaks for itself. People who frequently use ω have no problem with it; they actually find a huge advantage in it. So there is little point in rejecting it - just because it's a bit of posy Maths. One should be bilingual.
Interestingly, the only times that frequency is actually measured in cycles per second is when someone stands there with a stop watch and counts cycles. Any electronic frequency counter could just as easily give answers in terms of ω but we would need a new unit (say Hzn) to denote natural frequency.
Likes donpacino
I agree with it. However, what about p*n/60=f or n[rpm]=60*f[Hz]/p[pole pair number]?
One needs w in a lot of calculation, of course ,but-semantically-it is still not a frequency ,just a angle velocity and it is frequency linked by definition[w=2*pi*f]- in my humble opinion. What Hamlet would say: words, words..
There is a parallel here. We use dB (log10), Half Lives (log2) and Time Constants (logn). Most of us are happy enough with that. It's horses for courses. Get multilingual folks.
What do the units matter? You can deal with distance per time in many different scales, and with many different names. Km/hr. ft/sec, MPH, mach-1, 5C, furlongs per fortnight. What does it matter. It is the same concept for frequency (or inverse time). You use the units that make your ideas/solution/problem easy to express. None are correct or incorrect. Express them as Mega-rotations per moon-cycle if you want.
meBigGuy - I totally agree with you, however: The units do matter because one should not forget to mention the units. Very often I have experienced that people using the term "frequency" without mentioning if the mean Hz or rad/s. Or they are using the unit "Hz" and mean the angular frequency. Hence, one has to be very careful using the correct units.
But 'people' are generally pretty sloppy about such things. You only have to listen to conversation with the word 'dB' in it. e.g. "Is that dB Volts or dB Power?"
As long as the word "frequency" actually refers to Cycles per Second, then you can't go wrong. It's already been sail, above, that people who would have a difficulty with ω are probably not likely to need to use it.
But Units are not always just incidental. EM theory, using cgs and SI looks very different and it's not just a matter of swapping miles for kilometres. Of course, when you get to the botom of things, the PHysics is the same.
Multiplication by a constant does not change the units. Hertz are to radians/second as volts are to millivolts as cycles are to radians, as radians are to degrees, as ##h## is to ##\hbar##.
Correct (in principle), however - is (2*Pi) a constant or an angle in rad?
Are you seriously questioning whether 2 is a constant or PI is a constant?
Multiplying by 2pi changes the "actual frequency". Multiplying by 2pi radians changes the measurement quantity but not the "actual frequency".
2 *pi is a dimensionless constant. 2*pi radians is also a dimensionless constant.
radian is a dimensionless unit.
Quote 1: "Multiplication by a constant does not change the units."
Quote 2: "Are you seriously questioning whether 2 is a constant or PI is a constant?"
Sorry - My wording was a bit sloppy.
Of course, 2*Pi is a constant value - HOWEVER it is not dimensionless. It has the unit rad because it is an angle, is it not?
A radian has no dimensions; it is the ratio between two lengths. A degree is the same - the two lengths are not the same ones.
The two sides to the argument in this thread just reflect the different histories of the various proponents. Anyone who has actually produced a full side of algebraic 'workings' in the solution of a problem in oscillations will be aware of the advantages of ω. For someone who frequently uses the fact that 50Hz represents a cycle period of 20ms, or who deals with analogue TV signals, using ω would be loopy.
It's more big-endians and little-endians all over again.
From wikipedia:
The radian is the standard unit of angular measure, used in many areas of mathematics. An angle's measurement in radians is numerically equal to the length of a corresponding arc of a unit circle; one radian is just under 57.3 degrees (when the arc length is equal to the radius). The unit was formerly an SI supplementary unit, but this category was abolished in 1995 and the radian is now considered an SI derived unit.
LvW said:
From wikipedia:
The link you provided for SI Derived unit says that the radian is dimensionless.
It is a ratio of two lengths - it has to be dimensionless. How is that a problem?
I was trying to support what you said sophiecentaur.
Ditto. :smile:
I am afraid there is a confusion between "unit" and "dimension" (probably on my side due to my limited knowledge of the english language).
All I want to say is that multiplying a frequency "f" given in Hz (1/s) with "2Pi" leads to w=2Pi*f given in rad/s.
Therefore, the angle 2Pi has the unit "rad". As a consequence, the expression "wt" also is given in rad.
This was the background of my answer (post#22) to post #18 ("Multiplication by a constant does not change the units.")
Was there anything wrong or nor clear about this?
  • #31
No - everything clear. As I have mentioned there was a confusiuon on my side regarding "dimension" and "unit".
(See my post#22: ...it is not dimensionless. It has the unit rad).
Related to AC Signals - Radians and Degrees? Why do we use both?
1. What is the difference between radians and degrees?
Radians and degrees are two different units for measuring angles. Radians are based on the radius of a circle, while degrees are based on dividing a circle into 360 equal parts.
2. Why do we use radians instead of just degrees?
Radians are often used in mathematical calculations and in physics because they are a more natural unit for measuring angles. They are also preferred because they simplify many mathematical formulas and make them easier to work with.
3. When should radians be used instead of degrees?
Radians should be used when working with trigonometric functions, such as sine, cosine, and tangent, as these functions are defined in terms of radians. Radians are also commonly used in calculus and other advanced mathematical concepts.
4. Can radians and degrees be converted to each other?
Yes, radians and degrees can be converted to each other using a simple formula. To convert from radians to degrees, multiply the radian measure by 180/π. To convert from degrees to radians, multiply the degree measure by π/180.
5. Why do we use both radians and degrees?
Radians and degrees are both commonly used in different fields of study. While radians are preferred in mathematical and scientific contexts, degrees are more commonly used in everyday situations, such as giving directions or measuring angles on a map. Therefore, it is important to be familiar with both units and know how to convert between them.
  • Electrical Engineering
