Accelerated reference frames equation derivation question
In summary, the conversation discusses the derivation of the rate of change of the principle axis vectors, specifically how the approximation in line 4 becomes an equality in line 5. The answer lies in understanding derivatives and the limit of the difference quotient as the angle approaches 0.
charliepebs
my question comes from the portion of the derivation regarding evaluating the rate of change of the principle axis vectors. this begins by supposing a vector, Q, is rotating about axis n by δθ. Specifically, my question is how from step 4 to step 5 the approximation becomes an equality.
Q' can be approximated as:
1. Q' ≈ Q + (|Q|sinα)δθ(in direction of n cross Q)
2. Q' ≈ Q + |n cross Q|(in direction of n cross Q)δθ
3. Q' ≈ Q + (n cross Q)δθ
4. Q' ≈ Q + δθ cross Q
The derivation then states: "This means that we can express the derivative of this vector as:
5. (Q'-Q)/dt = (δθ cross Q)/dt
6. dQ/dt = δθ/dt cross Q
7. dQ/dt = Ω cross Q
My question is how the approximation in line 4 becomes an equality in line 5. Can someone explain this to me? The answer to your question lies in understanding how derivatives work. The derivative of a function f(x) is defined as the limit of the difference quotient (f(x+h)-f(x))/h as h approaches 0. In the case of your equation, the function is Q(θ), and the derivative is dQ/dθ. The difference quotient in this case is (Q' - Q)/δθ. Since δθ is a small angle, we can replace it with its limit as δθ approaches 0, which is dθ/dt. This gives us the equation (Q' - Q)/dt = (δθ cross Q)/dt, which is equivalent to the equation dQ/dt = Ω cross Q.
Related to Accelerated reference frames equation derivation question
1. What is an accelerated reference frame?
An accelerated reference frame is a coordinate system in which the observer is undergoing acceleration. This means that the observer is experiencing a change in velocity, either in terms of speed or direction.
2. What is the equation for an accelerated reference frame?
The equation for an accelerated reference frame is often referred to as the "centrifugal force equation" and is given by F = mω^2r, where F is the centrifugal force, m is the mass of the object, ω is the angular velocity, and r is the distance from the center of rotation.
3. How is the equation for an accelerated reference frame derived?
The equation for an accelerated reference frame can be derived using Newton's laws of motion and the concept of centrifugal force. By considering the acceleration of an object in a rotating reference frame, the equation can be derived and used to calculate the force experienced by the object.
4. What are the applications of the accelerated reference frame equation?
The accelerated reference frame equation has applications in various fields such as physics, engineering, and astronomy. It is used to study the effects of acceleration on objects in motion, such as in the design of centrifugal machines or in understanding the motion of celestial bodies in orbit.
5. Are there any limitations to the accelerated reference frame equation?
One limitation of the accelerated reference frame equation is that it does not take into account other forces acting on the object, such as friction or air resistance. Additionally, it assumes a uniform rotation and may not accurately describe the motion of objects in non-uniformly rotating frames.
