Acceleration across a frictionless surface
In summary, on a frictionless surface, an object pushed with a certain force and mass will accelerate at a constant rate according to F=ma. As soon as the force is removed, the object will continue at its final velocity indefinitely, as determined by Newton's first and second laws.
Sammy101
39
Hi, I am confused on the topic of friction. I thought of a question that I cannot answer.
What happens if you push an object with a certain amount of force and mass on a frictionless surface? According to F=ma, you will be able to get the acceleration of the object, but how will you know when the object stops acceleration? Will the object accelerate infinitely?
As soon as you stop applying force to the object it will cease accelerating. IE if you push a block, as soon as you take your hand off or stop pushing it will cease accelerating.
And so then it will just continue at a constant velocity right?
So, if you pushed on a 100kg object with 200N of force for 2s and then let go on a frictionless surface, the objects final velocity would be 4m/s because:
F=ma
200N=100kg(a)
a=2m/s^2
t=2s
velocity= 2m/s^2(2s) = 4m/s and that's how fast it would travel forever on a frictionless surface?
Yes, as soon as the force applied ceases, the object will continue at whatever velocity it was when you removed the force.
Thank you!
Newton's first law & 2nd law
Related to Acceleration across a frictionless surface
1. What is acceleration across a frictionless surface?
Acceleration across a frictionless surface is the rate of change of an object's velocity as it moves across a surface with no friction or resistance.
2. How is acceleration across a frictionless surface calculated?
Acceleration across a frictionless surface can be calculated using the formula a = F/m, where a is acceleration, F is the net force acting on the object, and m is the mass of the object.
3. What factors affect acceleration across a frictionless surface?
The only factor that affects acceleration across a frictionless surface is the net force acting on the object. Without friction, there is no resistance to slow down the object's motion.
4. How does acceleration across a frictionless surface compare to acceleration on a surface with friction?
Acceleration across a frictionless surface is typically greater than acceleration on a surface with friction. This is because frictional forces act as a resistance on the object, slowing down its acceleration.
5. What are some real-life examples of acceleration across a frictionless surface?
Some real-life examples of acceleration across a frictionless surface include ice skating, a hockey puck sliding on ice, and a car on an icy road. In all of these cases, the lack of friction allows for smoother and faster movement.
