Measuring Gravitational Waves w/ Elevator Accelerometer
In summary, an elevator in outer space has a precise accelerometer that measures the constant acceleration of the elevator. If a gravitational wave passes through the elevator, it will not affect the accelerometer since the acceleration measured is due to the rocket engine, not the geometry of spacetime. LIGO and similar detectors are not considered the most sensitive accelerometers as they measure changing tidal gravity, not proper acceleration. For the best possible gravitational wave detector, it would need to be free-floating in deep space with zero proper acceleration in any direction.
roineust
338
An elevator in outer space where there is negligible gravity, accelerates at the most precise constant acceleration that current technology enables.
Inside that elevator, resides an accelerometer that is the most precise accelerometer that current technology enables, but not more precise than what the elevator acceleration technology enables.
Will the accelerometer inside the elevator, show any change of measurments of constant acceleration, if a gravitational wave of any given magnitude and angle passes through the elevator?
If the accelometer will be able to detect that gravitational wave, will an iterpetation that says that LIGO and similar detectors are actually the most sensitive accelometers that exist, be a correct interpetation?
Likes docnet
No, because the acceleration measured by the accelerometer is due to the rocket engine, not the geometry of spacetime, and the gravitational wave only affects the geometry of spacetime.
Likes roineust
No. LIGO is not an accelerometer. It is a changing tidal gravity detector. Gravitational waves are waves of changing tidal gravity--or changing spacetime geometry, which is the same thing. The mirrors at the end of the arms in LIGO undergo zero proper acceleration; any relative motion can only be due to changing spacetime geometry.
(More precisely, the LIGO mirrors have zero proper acceleration in the plane of the arms--obviously since LIGO is on Earth everything in it has a constant proper acceleration due to being pushed upward by the ground, but that is all perpendicular to the plane of the arms and so can be ignored when analyzing LIGO's operation. But for the best possible gravitational wave detector, you would want it free-floating in deep space, with the whole thing moving inertially, with zero proper acceleration in any direction whatever.)
Likes cianfa72, vanhees71, hmmm27 and 2 others
Since the OP question is based on a misconception, which has now been corrected, this thread is closed.
Related to Measuring Gravitational Waves w/ Elevator Accelerometer
1. How does an elevator accelerometer measure gravitational waves?
An elevator accelerometer measures gravitational waves by detecting changes in acceleration caused by the passing of a gravitational wave. The accelerometer is designed to measure the acceleration of the elevator, and when a gravitational wave passes through, it will cause a small change in the acceleration that can be detected.
2. What is the principle behind using an elevator accelerometer to measure gravitational waves?
The principle behind using an elevator accelerometer is based on the fact that gravitational waves cause distortions in space-time, which can be detected through changes in acceleration. By measuring these changes in acceleration, scientists can indirectly detect the presence of gravitational waves.
3. How sensitive is an elevator accelerometer in measuring gravitational waves?
Elevator accelerometers are highly sensitive and can detect very small changes in acceleration. They are designed to be able to measure changes as small as one billionth of the force of gravity, making them an effective tool for measuring gravitational waves.
4. What are the limitations of using an elevator accelerometer to measure gravitational waves?
One limitation of using an elevator accelerometer is that it can only detect changes in acceleration in a specific direction. This means that it may not be able to detect gravitational waves coming from all directions. Additionally, external factors such as vibrations and noise can also affect the accuracy of the measurements.
5. How do scientists analyze the data collected from elevator accelerometers to confirm the presence of gravitational waves?
Scientists analyze the data collected from elevator accelerometers by looking for patterns and changes in acceleration that match the predicted effects of gravitational waves. They also compare the data with other measurements, such as those from gravitational wave detectors, to confirm the presence of gravitational waves.
  • Astronomy and Astrophysics
