Acceleration and velocity: Car and train problem
In summary, acceleration and velocity are two important concepts in understanding the motion of a car and a train. Acceleration is the rate of change of velocity, while velocity is the speed and direction of an object's motion. In the context of a car and train problem, acceleration is affected by factors such as the engine power and friction, while velocity is dependent on the distance traveled and the time taken. By understanding these concepts, we can better analyze and predict the motion of cars and trains in different scenarios.
Cat29
A train has a length of 118 m and starts from rest with a constant acceleration at time t = 0 s. At this instant, a car just reaches the end of the train. The car is moving with a constant velocity. At a time t = 14.0 s, the car just reaches the front of the train. Ultimately, however, the train pulls ahead of the car, and at time t = 34.6 s, the car is again at the rear of the train. Find the magnitudes of (a) the car's velocity and (b) the train's acceleration.
x = vt
x = ut + 0.5at^2
At t = 12s:
distance x = 0.5a14^2 = 98a
x + 118 = v14
14v - 118 = 98a
14v = 98a + 118
v = 7a + 8.43
At t = 34.6s:
distance y = 0.5a34.6^2 = 598.58a
y = v34.6
34.6v = 598.58a
v = 17.3a
Combining the two:
17.3a = 7a + 8.43
10.3a = 8.43
(a) v = 14.2 m/s
(b) a = 0.818 m/s^2[/B]
Is this correct? If it isn't, where did I go wrong? Thanks.
Cat29 said:
Is this correct?
Pretty much, but you quote too many significant figures in your answer. To justify three, you would need to keep another digit through all the calculations.
Likes Cat29
Okay. Thank you!
You can check your correctness, by considering the front of the train, starting at x0 = 118 meters, then you have x(t) = x0 + v0*t + (1/2)*a*t2, with your values of a, v, and t= 14 sec, and see if the constant velocity car and the front of the train reach the same x value at that time. You could do the same with the tail end of the train (starting at x(0) = 0, and see if they get to the same point at 34.6 seconds.
Related to Acceleration and velocity: Car and train problem
1. How do you calculate acceleration?
Acceleration is calculated by dividing the change in velocity by the change in time. It is represented by the equation a = (vf - vi)/t, where a is acceleration, vf is final velocity, vi is initial velocity, and t is time.
2. What is the difference between acceleration and velocity?
Acceleration is the rate of change of velocity over time, while velocity is the rate of change of position over time. In other words, acceleration measures how quickly an object's speed is changing, while velocity measures how fast an object is moving and in what direction.
3. How does a car's acceleration affect its velocity?
A car's acceleration directly affects its velocity. If a car is accelerating, its velocity will increase. If a car is decelerating, its velocity will decrease. If a car is traveling at a constant velocity, its acceleration will be zero.
4. How can you determine the acceleration of a train?
The acceleration of a train can be determined by measuring its change in velocity over a specific period of time. This can be done by using a speedometer or by measuring the distance the train travels and the time it takes to travel that distance. The formula for acceleration can then be used to calculate the train's acceleration.
5. What factors can affect the acceleration of a car or train?
The acceleration of a car or train can be affected by various factors such as the engine power, the weight of the vehicle, air resistance, friction, and the terrain it is traveling on. External forces such as wind and inclines can also impact the acceleration of a car or train.
