Acceleration change in freefall
In summary, the conversation discusses the concept of acceleration and its relationship to mass and gravity. It touches on the anecdote of Galileo and his experiment with dropping objects from the leaning tower of Pisa. The conversation also mentions the weak equivalence principle and the impact of air resistance on acceleration. The final part of the conversation delves into the equation for drag and its relationship to cross-sectional area.
uwmphysics
does anyone know the answer to this?
If the mass of an object in free fall is doubled, its acceleration
a. doubles
b. increases by a factor of four
c. stays the same
d. is cut in half
Go take a bowling ball and a rubber ball, drop them from the same height, and find your answer.
I thought everyone knew the anecdote of Galileo on top of the leaning tower of Piza.
Here's another question that you should look at to get a better grasp on acceleration... If I drop a pen on the moon, it will:
a) Float around
b) Fall to the ground
c) Go to the earth
d) Abducted by moon martian
So let me get this right, say an object in free fall towards the Earth suddenly increases its mass.
Now the movement of the object is determined by the curvature in space-time caused by the mass of the Earth am I right? But the object also has mass and curves the space-time, be it extremely small compared to the curvature of the Earth right? Are we saying that the space-time curvature between the two objects remain the same during the sudden mass increase?
Well, it would be one of those things where the difference is going to be something like 30 decimal places. The difference in forces, i.e. Newton's Second and Third Laws, are going to have a much greater impact on an object with a dynamic mass than relativistic effects (unless it is going super fast, then we could introduce general relativity).
I suggest looking up the weak equivalence principle or working it out for yourself. How do you find the acceleration of a free fall object?
Hint: Equate Newton's 2nd law with his gravitational law.
I'm sure the OP realized that this is a subforum for introductory physics and not advanced physics when he posted .
Actually, along with this, isn't the gravitational force of a more massive object slightly larger, although because of the Earth's mass it's unnoticable?
Yes, you are correct .
Not just "slightly larger" and certainly not "unnoticable". If object A has twice the mass of object B, then the gravitational force on A is twice that on B. But the question was about acceleration- and F= ma. If both mass and force double, what happens to a?
Ahhh you're right, I misused terminology, I meant isn't the acceleration slightly larger.
I understood your ,misused terminology :)
Yes, it is larger .
Wait a minute, an objects acceleration (due to gravity) is independent of its mass.
Free fall , doesn't take into account of mass . Acceleration is totally independent of mass .
Eg : If you drop a leaf and a tennis ball , you will notice that the tennis ball will reach the ground faster. This happens not because of the mass of the tennis ball , but the surface area of the tennis ball. Therefore , less air resistance or drag force acts upon the tennis ball , whereas the leaf has a much bigger surface.
When air resistance is equal to acceleration , terminal velocity is reached =)
I hope this helps though =) Cheers :P
Whoa whoa whoa... what about a small leaf... with a surface area less than that of the cross sectional surface area of a tennis ball...
It will still take longer.
And you mean when air resistance is equal to gravitational force.
Equilibration of forces.
I'm sorry that I did not state my assumptions before I quote on that statement .
Thanks though , and I meant ar resistance is equal to gravitational acceleration which is , g =)
Isn't drag force inversely proportional to the square root of the cross-sectional area or something?
Yes, I am pretty sure the original poster's question was from some kind of introductory physics class where the answer would obviously be the acceleration of an object is independent of mass, hence the Galileo and the leaning tower of Pisa anecdote. Doesn't every body know this? Galileo wanted to know if a heavier object fell faster than a lighter object, and so he took a boulder and a rock to the top of the leaning tower of Pisa and then dropped them both at the same time to see which would hit the ground first (thus accelerating the quickest). To his surpise, as the story goes (which is probably made up), both hit the ground at the same time.
The actual equation for drag is [itex]D = \frac{1}{2} \rho c_D u^2 A[/itex], so drag is proportional to area. (Logical, if you think about it - a larger surface area doesn't create less drag!) It refers to, in this case, the cross-sectional area normal to the direction of travel. So at terminal velocity, Drag = Weight resulting in a net zero force and hence constant velocity. That's the really short and simple version of drag, at any rate.
Yeah, mechanical physics sucked too much for me to remember anything from it.
FAQ: Acceleration change in freefall
1. What is acceleration change in freefall?
Acceleration change in freefall refers to the change in an object's velocity as it falls towards the ground due to the force of gravity. The acceleration of an object in freefall is always constant and equal to 9.8 m/s², regardless of the object's mass.
2. How is acceleration change in freefall different from other types of acceleration?
The main difference between acceleration change in freefall and other types of acceleration is that freefall acceleration is due to the force of gravity, while other types of acceleration are caused by a push or pull on the object. Additionally, freefall acceleration is always constant, whereas other types of acceleration can vary in magnitude and direction.
3. How does air resistance affect acceleration change in freefall?
Air resistance, also known as drag, can affect the acceleration of an object in freefall by slowing it down. As an object falls, it encounters air resistance, which increases as the object's speed increases. This can result in a decrease in the object's acceleration over time.
4. Can acceleration change in freefall be negative?
Yes, acceleration change in freefall can be negative if the object is moving in the opposite direction of gravity. For example, if an object is thrown upwards, it will initially have a positive acceleration due to the force of gravity pulling it down. However, as it reaches the highest point and starts falling back down, its acceleration will become negative.
5. How is acceleration change in freefall calculated?
The acceleration of an object in freefall can be calculated using the equation a = g = 9.8 m/s², where a is the acceleration and g is the acceleration due to gravity. This equation assumes that air resistance is negligible. If air resistance is taken into account, the equation becomes a = g - (D/m), where D is the drag force and m is the mass of the object.
