Acceleration doesn't cause the Twin Paradox?
In summary, in this scenario, the twin who accelerated sees her sister as aging more quickly than she would have aged if she had stayed at home. The twin who stayed at home sees her sister as aging more slowly than she would have aged.
  • #36
kamenjar said:
Nice formulas and diagrams... [stares confused, he only knows how to code]
On the related note, I thought that logic tells me that traveling at high speed causes slowing of the clocks... Why would "acceleration" cause the time difference when we consider this example:
Consider the case when twins traveled in parallel near the speed of light in 2 separate space ships and being close to Earth, the first one decided to land on Earth and the second one on a planet 30 LY away a few seconds later... They both send their pictures as they land.
For the second twin, the picture arrives a few moments later. The first one receives it after 30 years when she is 30 years older. It's obvious that they concluded that not acceleration but travel at near the speed of light caused the "differences in age".
Unless I am wrong, I didn't violate any GR/SR principles in this thought experiment, but I don't see the problem with this "perception" of clocks.
The twin paradox really doesn't happen in your example. For the paradox to occur, you have to have one of the twins go away and come back. You have to have them meet up in the same place they started.
The twin-paradox has a particular problem set-up:
One twin stays home while the other one goes on a journey and comes back. (That being said, I leave it to any General Relativity Experts to explain how this can be accomplished without any acceleration, as per their frequent claim.)​
Controversial Explanation of Twin Paradox:
I've added one detail. Instead of having the twin just go out to an arbitrary point in space, this twin actually has a destination, Planet X. I have a couple of "quizzes" based on the paradox with 99% of the speed of light right here:
The key to understanding the problem is the asymmetry involved. Whereas the stay-at-home twin merely sees the traveling-twin turn around and come back, the traveling-twin, during acceleration, sees the image of the stay-at-home twin suddenly jumps back! Whereas the stay-at-home twin sees the image of the traveling-twin departing for a large amount of time, and approaching for a small amount of time, the traveling-twin sees both parts of the journey take an equal amount of time.
Why is it controversial?
General Relativity Experts will always claim that this (the sudden lurching away of the image) is nonsense. • They will say the Lorentz Transformation is local and has no effect on faraway events. • They will claim that straight lines do not exist. • They will claim that coordinate systems are a religion. • They will say there is no clear meaning for distant "location" or "velocity" or "now," or that these notions are ill-defined. • I've even seen them argue that "reality" is an ambiguous concept.​
And I certainly agree that these concepts are ill-defined, but that is not a problem with the concepts. That is a problem of the text-book writers whose responsibility should include giving clear definitions.
The point is, though, that I do not understand the General Relativity Expert's arguments. Because I don't understand their arguments, the assumption is that I lack the education to understand their arguments, which I can acknowledge. Those arguments I listed don't make sense to me. But when we say "it doesn't make sense" we need to figure out what that means.
We can classify the various arguments of the General Relativity experts, and in exactly what way they don't make sense:
  • the Lorentz Transformation is local and has no effect on faraway events (Wrong. The Lorentz Transformation affects every event in spacetime.)
  • straight lines do not exist. (Not even wrong. How would you know that no objects move in straight lines if the concept of straight lines doesn't exist?)
  • coordinate systems are a religion (total non sequitur)
    no clear meaning for distant "location" or "velocity" or "now," (wrong, certainly wrong in the context of Special Relativity)
  • these notions are ill-defined. (Right. But that fault lies with the definers.)
  • Reality is an ambiguous concept. (total non sequitur. Doesn't that sound more like a religion than coordinate systems?)
  • #37
I'm not not quite sure what you mean by "the image of the stay-at-home twin suddenly jumps back". Nothing special happens to the image other than the traveling twin seeing it go from receding to approaching. In other words, the traveling twin also just sees the stay -at-home twin turn around and come back. The difference is that the traveling twin sees this happen immediately upon turn around, while the stay at home twin must wait for the light carrying the information about the turn around to travel the distance between them. This is what leads to the unequal times each sees in the halves of the journey.
  • #38
Can you verify that with some math, perhaps? You're wrong, but unless you actually perform the Lorentz Transformation on the relevant events, you won't see why. But even without doing the math, you should be familiar with the idea of "stellar aberration." It's the same phenomenon, but to the side, instead of directly in front of you.
(Of course, after a Lorentz Transformation is done, common consensus of General Relativity Experts is that you should disregard the distance coordinates of events after Lorentz Transformation as meaningless, or nonsensical, as described in my previous posts.)
  • #39
Take care, also, to distinguish, also between image distance and simultaneous distance. If you change this sentence to "The simultaneous distance to Earth is the same before and after the transformation" then it would be true.
But the image distance changes.
Attached is a space-time diagram distinguishing between radar-distance, image distance, and simultaneous distance.
  • #40
When I did this a long time ago, I concluded that if each twin were holding a clock that could be seen at great distance, the turnaround twin, at moment of turnaround would see the distant clock:
1) Change color from redshift to blueshift
2) Shrink in size, and become brighter
3) change rate
However, there would be no jump in the hands on the clock - just rate change.
I gather, by 'image distance' you are referring to interpreting the image size (a direct observable) as a distance based on knowledge of rest frame size and some model. However, you have a choice of models, including which optical effects you compensate for or not. The image size is an observable. Any particular image distance is a model dependent interpretation.
[Edit: And I think parallax distance would be the same as naively interpreted image size distance]
  • #41
3) change rate
Yes, yes, yes, and yes. All correct.
That's not exactly what I'm referring to. I'm referring to the intersecton of the observer's past light-cone with the world-line(s) of the object. The distance to the image is mathematically identical to the distance to the event that produced the image. If you're doing everything right, (i.e. if you choose the right model) it should work out the same.
Here is a conceptual animation of what I would do to find the image distance to an object:
with some discussion of it here:
http://www.spoonfedrelativity.com/pages/Is-Lorentz-Contraction-Invisible.php
and last August, I opened a thread about this in Physics Forums:
https://www.physicsforums.com/showthread.php?t=520875
  • #42
It seems like this equivalent to the following wording:
I pretend I was always moving the way I am now, then I figure out what distance I would have been from the object at the time its image was emitted. Distance here may be taken to be Lorentz 'ruler distance' based on my current simultaneity extended back in time.
Assuming you are now moving inertially, I believe this distance will be the same as image size distance (naively interpreted) and also the same as parallax distance. It will also be the same as radar distance to the emitting event determined by someone who really was always moving the way I am now.
So then we get into philosophy. Is it reasonable to interpret observations according to a counterfactual model (I wasn't always moving the way I am now)? I've expressed the view that it is perfectly feasible to do this, but not required or preferred.
  • #43
Yes, well said.
The same thing is done with a rotation transformation. You start with the mapping of events in space, then you ask the question, what would things look like if I had ALWAYS been facing to my left? And boom, there you are, facing left. And the light is reaching you as though you had always been facing left.
Similarly, The Lorentz Transformation Equation is mapping that counterfactual into the factual.
When you jump on a passing trolley, you are now in the reference frame of that trolley; your experience of events will be exactly the same as the other people on board that trolley. There is nothing about your history that can affect your current experience.
So the question to ask then is whether it is "just feasible" to do this, or is it "required?"
I think it is required.
Is there some kind of loophole where your immediate experience after jumping on a trolley, or turning your head left is affected by your experience before jumping on a trolley, or turning your head left?
  • #44
Well, if you change direction quickly enough, you will see extremely superluminal changes in image distance. You might argue that turning your head can create a superluminal illusion, but that's just it - everyone takes it to be illusion because you can feel rotation.
Similarly the always (or long time) inertial observer has every reason to treat the straightforward interpretation of measurements as being 'as real as anything gets' in physics. In contrast, someone going through extreme G-force to reverse direction has no rational reason to believe their direction change caused distant objects to move superluminally. They might prefer to equate their situation to the the head turner, and treat the visual changes as optical rather than physical phenomena. The very simplest way to do this is to pick any inertial frame for the analysis of the whole trip, translating measurements to it. Then, you have no surprising interpretations. Alternatively, you can choose any number of global coordinate schemes that mesh changing local frames together in such a way as to avoid particular undesirable interpretations (e.g. superluminal motion).
We've been down this road before. Many here grant that your preferred approach is a feasible way analyze any SR situation. We differ only when you want to insist it is the only or strongly preferred approach.
  • #45
The alternatives I can think of are:
(1) Coordinates of distant events are observer dependent.
(2) Coordinates of distant events are theory dependent.
(3) Coordinates of distant events are ambiguous and undefinable.
I'm trying to make point #1 here, and I think you are either trying to make point #2 or point #3.
As for point #3, I don't know how to respond to that, but...
As for point #2, If you use spherical coordinates, Rindler Coordinates, Painleve Coordinates, FLRW coordinates, Schwarzschild Coordinates, Cartesian Coordinates, Minkowski Coordinates, then YES the coordinates are theory dependent. Coordinates are arbitrary in this sense. Description based coordinates can be defined whimsically. Once defined whimsically, description based coordinate systems can become difficult or even impossible to Lorentz Transform.
But Lorentz Transformation and Rotation are transformations of a completely different character. They don't change the description of the coordinates; they change the observer.
And in a transformation that changes the observer, you can't just shrug off changes in the positions of events as illusionary. They are real changes in the observer's perspective.
If you want more information on what I mean by "description dependent" vs "observer dependent" transformations, see http://www.spoonfedrelativity.com/pages/Types-of-Transformations.php.
  • #46
When surprising ideas are defined with clarity, they may appear to be ridiculous. However, if an idea is true, it should be possible to defend the idea, even if, at first, it appears ridiculous.
When we have an a priori idea of what represents an "undesirable interpretation" do you think it is appropriate to take extra steps to hide the facts so that this interpretation is hidden, or wouldn't it be more appropriate to acknowledge the facts, and expand our vocabulary of ideas until we can explain WHY this doesn't break the laws of Special Relativity?
The correct answer is going to "sound" ridiculous. But if it is expressed with clarity, it can be defended.
The fact is when I am on a merry-go-round, distant objects DO move faster than the speed of light RELATIVE TO ME. But in no way does that mean that the distant objects have traveled faster than the speed of light in any static reference frame. When I am on a merry-go-round, my reference frame is continuously changing.
(1) We can continue to make the claim that the experience of the person on the merry-go-round represents a single local reference frame, and just ignore the non-local objects which are (mathematically, but not really) moving faster than the speed of light.
(2) Or we could be bold, (stand up to ridicule,) and make the claim that the person on the merry-go-round is continuously changing their reference frame, and acknowledge the objects which are moving faster than the speed of light relative to the observer, but NOT relative to any static reference frame.
