Acceleration in arbitrary trajectory (differential geometry)
In summary, the acceleration of a trajectory can be written in terms of the speed, unit vectors tangential and perpendicular to the trajectory, and the radius of curvature. The second term in the equation is obtained by taking the derivative of the tangential unit vector with respect to arc length, which measures the curvature.
Zatman
86
Show that for any trajectory r(t) the acceleration can be written as:
[itex]\mathbf{a}(t)=\frac{dv}{dt}\hat{T}(t)+\frac{v^2}{\rho}\hat{N}(t)[/itex]
where v is the speed, T is a unit vector tangential to r and N is a unit vector perpendicular to T, at time t. rho is the radius of curvature.
2. The attempt at a solution
[itex]\mathbf{a}=\frac{d\mathbf{v}}{dt}=\frac{d}{dt}(v\hat{T})[/itex]
[itex]=\frac{dv}{dt}\hat{T}+v\frac{d\hat{T}}{dt}[/itex]
Since we can write
[itex]\frac{1}{\rho}\hat{N}=\frac{d\hat{T}}{dt}[/itex]
This gives
[itex]\mathbf{a}=\frac{dv}{dt}\hat{T}+\frac{v}{\rho}\hat{N}[/itex]
I can't see where to get the other 'v' from, in the second term.
##v\frac{d\hat{T}}{dt}= v \frac{d\hat T}{ds}\frac{ds}{dt}= v^2\frac{d\hat T}{ds}##. But the curvature ##\kappa## is ##\kappa = \left|\frac{d\hat T}{ds}\right|## so ##
v^2\frac{d\hat T}{ds} = v^2\kappa \hat N(t) = \frac{v^2}{\rho}\hat N(t)##.
Likes 1 person
Got it, thanks.
Missed that it is the derivative of [itex]\hat{T}[/itex] with respect to arc length that measures curvature.
Related to Acceleration in arbitrary trajectory (differential geometry)
1. What is acceleration in an arbitrary trajectory?
Acceleration in an arbitrary trajectory refers to the rate of change of velocity with respect to time in a curved path or trajectory. It takes into account both the magnitude and direction of the change in velocity.
2. How is acceleration calculated in differential geometry?
In differential geometry, acceleration is calculated using the second derivative of position with respect to time. This involves taking the derivative of the velocity vector, which represents the rate of change of position, with respect to time.
3. What is the difference between tangential acceleration and normal acceleration?
Tangential acceleration refers to the component of acceleration that is in the same direction as the velocity vector, while normal acceleration refers to the component of acceleration that is perpendicular to the velocity vector. In an arbitrary trajectory, both tangential and normal acceleration may be present.
4. How does acceleration affect the motion of an object along an arbitrary trajectory?
Acceleration affects the motion of an object along an arbitrary trajectory by changing the magnitude and/or direction of its velocity. This can cause the object to speed up, slow down, or change direction as it moves along the curved path.
5. What other factors can affect acceleration in an arbitrary trajectory?
In addition to the object's initial velocity, acceleration can also be affected by external forces such as gravity, friction, and air resistance. These forces can cause the object to deviate from its intended trajectory and experience changes in acceleration.
