Acceleration in Rindler coordinates
In summary: The acceleration is the rate of change of the velocity, and it is always the same in any inertial frame.
Ali.Sadeghi
[Mentors note: this thread was split off from an older discussion of Rindler coordinates]
Can somebody help me understand why acceleration along the hyperbola is constant?
To be more precise: assume (X,T) is the inertial coordinates and (x,t) the corresponding Rindler transformations.
x=Xcosh(aTc )
t=Xc sinh(aTc )
A uniformly accelerated frame moves along the curves with constant x.
What do we men by fixed acceleration here? is it second derivative of x relative to t? if x is constant then its first and second derivatives are of course zero. The second derivative of X relative to T cannot be a constant either, because that would imply a parabolic and not hyperbolic path with no limit on speed of light.
The only possibility that I can see is second derivative of X relative to t. is that indeed what we mean by constant acceleration along the hyperbola? And if so how can one prove that it is constant (equal to a)?
x=Xcosh(aTc )
t=Xc sinh(aTc )
By acceleration is meant what is measured by an accelerometer. In SR, this is predicted (as a magnitude) to be the norm of the 4-acceleration, which is the derivative by proper time of the of the 4-velocity. As such, it (proper acceleration) is an invariant scalar that would be computed to be the same in any coordinates used to describe the world line (consistent with the idea that change coordinates used to describe the world do not change readings on a given measuring device).
Consider an inertial frame in which the spaceship is at momentarily at rest. This would be the inertial frame of a dropped object on the spaceship, because the spaceship and the object are moving at the same speed at the moment that the object is released (and we'll take that moment to be time zero in that frame).
In this inertial frame, the the velocity of the ship at time zero is zero, but the first derivative of that velocity is not. That first derivative, evaluated at t=0, is the Rindler acceleration ##a##. It is easy enough to show that it is a constant, meaning that you'll come up with the same value no matter what the speed of the ship is at the moment that the object is dropped.
All of this is equivalent to what PAllen said above, of course.
Related to Acceleration in Rindler coordinates
1. What are Rindler coordinates?
Rindler coordinates are a coordinate system used in relativity to describe the acceleration of an observer in flat spacetime. They are often used in the study of black holes and other accelerating systems.
2. How do Rindler coordinates relate to acceleration?
Rindler coordinates can be thought of as a curved coordinate system that is attached to an accelerating observer. They are useful for describing the motion and effects of objects in an accelerating frame of reference.
3. What is the difference between Rindler coordinates and inertial coordinates?
Inertial coordinates are a coordinate system used to describe motion in a non-accelerating frame of reference, while Rindler coordinates are used for describing motion in an accelerating frame of reference. In Rindler coordinates, the observer is always accelerating and cannot be at rest.
4. How are Rindler coordinates used in the study of black holes?
Rindler coordinates are often used to describe the motion and effects of objects near the event horizon of a black hole. They allow for a better understanding of the behavior of light and matter in the strong gravitational field near a black hole.
5. What are some applications of Rindler coordinates in physics and engineering?
Rindler coordinates are used in various fields of physics and engineering, such as in the study of black holes, relativistic effects in high-speed particle accelerators, and in the design of spacecraft trajectories. They are also used in developing theories of gravity and for understanding the behavior of objects in accelerating systems.
