Acceleration of a person jumping off of a bathroom scale
In summary, the man jumps off a bathroom scale weighing 72 kilograms, and determines that he experiences an acceleration of 1.9 meters per second squared.
Physics_Amazing
A 72 kg person jumps up off a bathroom scale. Determine the acceleration of the person when the scale reads 840 N.
Fnet=Ma
Fg=mg
fnet=ma
Fn-fg=ma
840 - (72)(-9.8) = 72a
a= 840 - (-705.6) /72
a=21.19m/s^2
The correct answer is 1.9m/s^2 unsure of how to get that
There are two external forces acting on the man. Name them.
Normal and Gravity
Yes I see you have that correct.
Did you ever learn arithmetic? :smile:Carefully carry the units...I don't see how you could screw this up! (and I'm a professional).
g = +9.8 m/s2 should be substituted in the equation. You already put the minus sign in the equation Fn - fg = ma in front of fg to indicate that it is down. Then you put an extraneous negative sign when you substituted the numerical value, essentially saying that the weight force is up. You can only say that the weight is "down" once, not twice.
Likes Physics_Amazing and hutchphd
Thank you.
Likes kuruman and berkeman
Physics_Amazing said:
Thank you.
A good sanity check would be if you did exactly the same procedure for when the scale reading is the actual weight of the man. You should, of course, get zero.
Homework Statement:: A 72 kg person jumps up off a bathroom scale. Determine the acceleration of the person when the scale reads 840 N.
Relevant Equations:: Fnet=Ma
Fg=mg
fnet=ma
Fn-fg=ma
a=21.19m/s^2
This is correct if the bathroom scale is attached to the ceiling and the person is jumping down.
Likes jbriggs444
Fg=mg
fnet=ma
Fn-fg=ma
a=21.19m/s^2
The double negative which arises where you plug-in values for Fg (-9.8) for the downward gravitational acceleration is incorrect because you already account for directionality by minusing Fg from Fn (Fn - Fg).
Fg=mg
fnet=ma
Fn-fg=ma
a=21.19m/s^2
It would be helpful to carry units throughout the math/arithmetic. Also, the parantheses in the second-to-last step should encompass the whole numerator term, (840-705.6)/72 which will get you to around just below 2 or 1.9 m/s^2.
FAQ: Acceleration of a person jumping off of a bathroom scale
What is acceleration?
Acceleration is the rate of change of an object's velocity over time. It is a measure of how quickly an object is speeding up or slowing down.
How does acceleration affect a person jumping off of a bathroom scale?
When a person jumps off of a bathroom scale, they experience a brief moment of acceleration as they push off the scale and begin to fall towards the ground. This acceleration is caused by the force of gravity pulling the person towards the Earth.
What factors can affect the acceleration of a person jumping off of a bathroom scale?
The acceleration of a person jumping off of a bathroom scale can be affected by their initial velocity, the force of gravity, air resistance, and the surface they are jumping onto.
How can acceleration be calculated for a person jumping off of a bathroom scale?
Acceleration can be calculated using the equation a = (vf - vi)/t, where a is acceleration, vf is final velocity, vi is initial velocity, and t is time. In the case of a person jumping off of a bathroom scale, the initial velocity would be 0 and the final velocity would be the speed at which they hit the ground.
Can a person jumping off of a bathroom scale experience negative acceleration?
Yes, a person jumping off of a bathroom scale can experience negative acceleration if they are slowing down as they fall towards the ground. This could happen if they are wearing a parachute or if they hit a surface that provides resistance, such as a trampoline.
