Acceleration of falling object on impact
In summary, the person is trying to calculate the height at which an object needs to be dropped in order to hit the ground with an impact of 1000g's. They have found equations for calculating the velocity and height at impact, but are unsure about the duration of impact and how to factor in the mass of the object. They also mention the difficulty of estimating the deceleration distance without proper equipment and suggest using experimentation to find the most accurate results.
sunny0302
I have been out of school for a few years so my physics is rusty. I need help figuring something out for my job. I need to know how high I must drop an object so that it hits the ground with an impact of 1000g's. The object is a cylindar and weighs 2lbs.
I have been confusing myself. I know that the object will fall with 1g acceleration. I think need an equation that allows me to find the instantaneous acceleration at the moment of impact. I think I can assume an infinitely hard ground for now. I have found that instantaneous acceleration is delta v/delta t where t->0.
If a=9806 m/s^2 then as t-->0, the velocity would be 9806 m/s?
So then I think I need to use another equation to back out the height
I found this equation for free-fall with no air resistance but I'm not sure it helps.
y(t)=-1/2*g*t^2 + v_o*t + y_o
I found this equation for impact vel just before impact = sqrt(2*g*h). But if I set it equal to 9806 I get h=4,903,000 meters...that seems very high.
I am also worried when the equations don't take mass into account.
Another option I thought of:
F=ma
F=(.907 kg*9806m/s^2)
F=8894N
And then I would need some sort of equation that let's me back height out of Newtons.
Can anyone help me? I'm going in circles.
No. For any velocity, if the object comes to rest in a time t->0, the acceleration of the object tends to infinity!
[tex]<a> = \frac{\Delta v}{\Delta t} = \frac{v}{\Delta t}[/tex]
So, unless you can estimate the duration of impact, it is difficult to find out the velocity required to produce that acceleration. It is very likely that the velocity required is much less than 9806m/s, since the object is likely to stop in much less than a second.
This equation comes from conservation of energy.
[tex]\Delta Potential Energy = \Delta Kinetic Energy[/tex] (magnitude-wise)
The mass actually cancels out, so no worries there.
[tex]m g h = \frac{1}{2} m v^{2}[/tex]
[tex]v = \sqrt{2gh}[/tex]​
Ok, so if I assume it stops in .01 s, the velocity changes to 98.06s.
The using the second equation I would get h=490.3 meters.
Is there any good way/equation to estimate how long it would take to stop so I can get a better height estimate?
If an object falls from a height h, and stops in a distance x, the deceleraton a is gh/x meters per second2. If h is 10 meters, and x = 1 cm, then a = 1000 g's.
Bob S
Bob S
Well, that seems simple enough. Thanks!
It seems simple, but figuring out the "x" isn't. That x is NOT something you can just approximate off the top of your head, either. You must do some research to figure this out. Also, keep in mind that the "x" will change as the drop height changes.
Anyway, if you're just going to approximate x, you might as well skip all the math and physics and this entire thread, and simply guess the height. It saves a lot of trouble and calculation, and the end result is pretty much the same...
Assuming I know the weight, cross-sectional area and material of the object, are there any equations that can help me figure x out? Are there standard "give" estimated values for the ground. For instance, 40N of force makes the ground give .1 cm?
calculating the length/duration of the deceleration zone is tricky, it would be much easier to measure it if you have access to accelerometers, otherwise you have to think about orientation of the object under impact, the stiffness and geometry of the object, dynamics of crumple zone etc etc…. it could get pretty complex pretty quick
Yeah, exactly. It could, and should get VERY complex VERY quickly. There's so many variables to consider, the properties of the ground, the object, etc. I think it's something that can only be approximated sufficiently with experiment. And, actually, that doesn't seem very difficult. Just take the cylinder and drop it, and measure how big of a dent it made.
Depending on the variables though, it might make no dent at all. In which case you should look at better equipment...accelerometer, high speed camera, whatever else there might be. Hell, you could probably even figure out how to use an egg to help you get the results.
Ultimately the sophistication of the measuring equipment comes down to how much your job really cares about getting accurate results. If they say that they want you to figure it out only using google and your imagination, tell them to be prepared for an error factor of a few hundred percent at best, imo.
As seen in the previous responses, this is a very complicated question. Which to me, implies that the wrong question may have been asked. You might want to discuss this with whoever posed the question, and find out from them what it really is they want to do. In other words, I doubt that what they really want to do is "hit the ground with an impact of 1000g's" since that is a pretty poorly defined request.
Thanks so much for your input. There is another way to test the shock. There is a machine but it costs $ so I think they wanted to see if they could just drop it and get about the same results. It looks like, unless they are willing to drop it many times from different heights and then measure the deformity of the ground, it can't really be done.
Thank you so much for your advice. I was feeling pretty dumb struggling with this question and I'm glad to know at least that it is complicated.
Bob S
Can you explain how did you get this relation- a=g*h/x ?
I think you are talking about drop testing on a rig as opposed to the sort you might use for key fobs for example. Drop rigs are used for components that are fitted to other assemblies and usually at specific accelerations in each axis and fixing the test sample in place with fixtures representative of those in the assembly. Go on, stop us guessing, tell us what this is and what testing you are wanting to carry out and why, it will give you more focussed feedback, and stop the answers heading in the wrong direction.
F=ma
F=8894N
If you don't mind my asking... I am a physics student and i have never heard of impact being measured in g. (I may be wrong) I'm going to run the scenario through my professor and get back to you on that.
Related to Acceleration of falling object on impact
1. What is acceleration of a falling object on impact?
The acceleration of a falling object on impact is the rate at which the object's velocity changes as it falls towards the ground. It is affected by factors such as the object's mass and the force of gravity.
2. How is acceleration of a falling object on impact calculated?
The acceleration of a falling object on impact can be calculated using the formula a = (v-u)/t, where a is acceleration, v is final velocity, u is initial velocity, and t is time.
3. Does the acceleration of a falling object on impact change based on the object's mass?
Yes, the acceleration of a falling object on impact is directly proportional to the object's mass. This means that a heavier object will experience a greater acceleration on impact compared to a lighter object.
4. How does air resistance affect the acceleration of a falling object on impact?
Air resistance can have a significant effect on the acceleration of a falling object on impact. As the object falls, it experiences a force from the air pushing against it, which can slow down its acceleration. Objects with greater surface area will experience more air resistance and have a lower acceleration on impact.
5. Can the acceleration of a falling object on impact be greater than the force of gravity?
Yes, the acceleration of a falling object on impact can be greater than the force of gravity. This can occur if the object is propelled or has an external force acting on it, resulting in a greater acceleration than what gravity alone would cause.
  • Mechanics
  • Classical Physics
  • Mechanics
