Acceleration of the end of a hinged rod in a pulley system
In summary: The tangential acceleration would be L*(alpha)^2 .In summary, the conversation discusses a problem involving a system of five simultaneous equations and the attempt to solve for the acceleration of a block and a mass connected by an inextensible string. The equations include tension, mass, radius, and angular acceleration and velocity. The missing equation is found by relating the tangential acceleration of the block to the acceleration of the mass, resulting in a solution for the overall acceleration.
deusy
As shown in image.
2. Homework Equations
Moment of inertia of pulley = [tex] 1/2*M*R^2 [/tex]
Moment of inertia of rod (about end) = [tex] 1/3*M*L^2 [/tex]
Acceleration of end of rod in theta direction = [tex] L*α [/tex]
Acceleration of end of rod in radial direction = [tex] L*ω^2 [/tex]
Pretty sure this question requires solving a system of five simultaneous equations, but I cannot work out the final one.
Note:
T1 = tension of rope attached to A
T2 = tension of rope attached to B
M = mass
R = radius
α = angular acceleration
ω = angular velocity
Positive movement defined upwards
From free body diagram of block A:
[tex] T1- M(A)*g = M(A)*a(A) [/tex]
From taking the moment around the pulley:
[tex] T1*R(pulley)-T2*R(pulley)=I(pulley)*α(pulley)=1/2*M(pulley)*R(pulley)^2*α(pulley) [/tex]
From taking the moment around the rod:
[tex] T2*L-M(rod)*g*L/2=I(rod)*α(rod)=1/3*M(rod)*L^2*α(rod) [/tex]
From polar coordinates:
[tex] a(A) = -R(pulley)*α(pulley) [/tex]
One equation missing
Once I work out the last equation and solve for α(rod), I should be able to use Pythagoras to work out the magnitude of the acceleration from:
[tex] a=((α(rod)*L)^{2}+((L*ω^2)^{2}))^{1/2} [/tex]
Can anyone see what I'm missing and/or if I'm going wrong in any of the other equations? Been trying this question for hours and can't get my head around it.
I think there are only four variables so four equations should be enough .
I guess you have considered anticlockwise positive , in which case you have a sign issue .
Apart from that everything else looks fine :smile: . I hope I am not overlooking something.
Vibhor said:
I think there are only four variables so four equations should be enough.
There's five in my equations, unless one I can work out from something else?:
[tex] a(A), T1, T2,
α(rod), α(pulley) ?
[/tex]
Otherwise I think I still need a fifth equation.
Thanks for the sign tip, though!
[tex] a(A), T1, T2,
α(rod), α(pulley) ?
[/tex]
OK .Fair enough .
The tangential acceleration of point B is related to the acceleration of the block .
Are you implying there's another equation I can get from this?
Yes .
Replace the rod attached to point B with a mass M .
How would acceleration of block A and mass M be related ?
Would it be that:
[tex] a(A)=-a(B[tangential]) = -L*ω^{2} [/tex]
As the displacement of A is the negative displacement of B (if considering it B as mass), so [tex]a(A)=-a(B)[/tex] in the tangential direction? This allows me to calculate a(A) without solving simultaneously, which doesn't seem right to me.
Yes . The magnitude of tangential acceleration of B should be equal to that of A as they are connected by an inextensible string .
This should give you the answer .
What values are you getting for tangential and radial acceleration of B ?
I am getting:
[tex] a[radial]=7.677 m/s/s [/tex]
[tex] a[tangential] = 6.728 m/s/s [/tex]
(magnitudes only)
These are not giving me the correct answer for overall acceleration.
What is the given correct answer ?
I won't know it until I get it right unfortunately, this is a question from an online task.
I am getting 8.938 m/s2 as magnitude of tangential acceleration .
I am just doing:
[tex]0.8*2.9^2=6.728[/tex]
deusy said:
I am just doing:
This is radial acceleration .
FAQ: Acceleration of the end of a hinged rod in a pulley system
What is the acceleration of the end of a hinged rod in a pulley system?
The acceleration of the end of a hinged rod in a pulley system depends on the length and mass of the rod, as well as the forces acting on it. It can be calculated using Newton's second law, which states that the acceleration of an object is directly proportional to the net force on the object and inversely proportional to its mass.
How does the length of the rod affect its acceleration in a pulley system?
The length of the rod affects its acceleration because it determines the distance the rod needs to travel in a given time. A shorter rod will have a shorter distance to travel, resulting in a faster acceleration. Additionally, a longer rod may experience more resistance and friction, which can also affect its acceleration.
What role does the mass of the rod play in its acceleration in a pulley system?
The mass of the rod also plays a significant role in its acceleration. A heavier rod will require more force to accelerate compared to a lighter rod. This is because the mass of an object is directly proportional to its inertia, meaning it will resist changes in its motion.
How does the pulley system affect the acceleration of the hinged rod?
The pulley system affects the acceleration of the hinged rod by changing the direction of the applied force. As the rod moves through the pulley, the direction of the force changes, resulting in a change in acceleration. Additionally, the friction and tension in the pulley system can also affect the acceleration of the rod.
Can the acceleration of the hinged rod in a pulley system be increased?
Yes, the acceleration of the hinged rod in a pulley system can be increased by increasing the net force acting on the rod. This can be achieved by either increasing the applied force or decreasing the mass of the rod. Additionally, reducing friction and resistance in the pulley system can also increase the acceleration of the rod.
