Acceleration of Universe: centrifugal force?
In summary, the acceleration of the universe is the rate at which the expansion of the universe is increasing, caused by a mysterious force called dark energy. Centrifugal force is not directly related to this acceleration, as it only applies to rotating objects. The acceleration of the universe is not caused by centrifugal force, but rather by the gravitational force between all matter and energy. This acceleration causes the expansion of the universe to speed up, with galaxies and other objects moving away from each other at an increasing rate over time. Therefore, the acceleration of the universe is not constant, but is believed to be increasing over time.
petermoose
Is it 'possible' (that is, if you say not, can you conclusively show the negative), that the entire observed acceleration in the expansion Our Universe, created some 13.7 x 10^9 years ago in the Big Bang, is due solely to centripetal force throughout, caused by a complex spinning/rotating/tumbling (initiated in the Big Bang, but, itself, slowing over time as the Universe expands--much as would an ice skater, who, after first initiating her spin and then gradually pulling her arms in tight to her chest in order to spin faster and faster, might then--instead of stopping suddenly in her finale--choose to reverse the process by gradually letting her arms stretch out--this last movement being comparable, in its 1-dimensional way, to our Universe's many-dimensional rotation rate slowing over time with its accelerated expansion), all relative to a surrounding massive Multiverse (say, of other--perhaps distant, perhaps not so--surrounding universes, probably created in other separate 'big bang' events), so that this acceleration is then observed by us in the actual middle of our 'Observable' (i.e., the 93 Gly in diameter) Universe (somewhere in the midst of--and probably no more than a speck within--our entire Big Bang Universe) in the form of distant galaxies and galaxy clusters rushing away from us in all directions and at increasing velocities with distance, so that, thereby, there is actually no need to posit some 'dark energy' continuously creating new space within Our Universe, as all of the acceleration in the expansion is due to said centripetal force pulling apart our (non-rigid) Universe?
Space news on Phys.org
No, it is not. This has been debunked on this forum numerous times. It would imply a preferred frame of refrence thereby violating the Cosmological Principle and all known experiments.
That's not how it works. If you are proposing a model for the universe, it's up to you to justify it based on some kind of positive evidence. It's not up to us to "conclusively show the negative".
However, in this case the model you are proposing has already been considered and falsified; it makes predictions that we know to be wrong. See below.
No. Any model in which the universe is "rotating", so that what we see as "accelerated expansion" is due to the effects of the rotation, would not be isotropic; things would look different in different directions. They don't.
(If you search PF for threads on "rotating universe", you will find previous discussions where this same point was made.)
Thread closed as this topic has already been discussed in multiple PF threads.
FAQ: Acceleration of Universe: centrifugal force?
1. What is the acceleration of the universe?
The acceleration of the universe refers to the rate at which the expansion of the universe is increasing. This acceleration is currently believed to be caused by a mysterious force called dark energy.
2. How is centrifugal force related to the acceleration of the universe?
Centrifugal force is not directly related to the acceleration of the universe. The acceleration of the universe is mainly influenced by the gravitational force between all the matter and energy in the universe, while centrifugal force only applies to rotating objects.
3. Can centrifugal force cause the acceleration of the universe?
No, centrifugal force cannot cause the acceleration of the universe. As mentioned before, this acceleration is mainly due to the presence of dark energy and the gravitational force between all the matter and energy in the universe.
4. How does the acceleration of the universe affect the expansion of the universe?
The acceleration of the universe causes the expansion of the universe to speed up. This means that galaxies and other objects are moving away from each other at a faster rate than they were in the past, and this expansion is expected to continue in the future.
5. Is the acceleration of the universe constant?
No, the acceleration of the universe is not constant. It is currently believed that the acceleration is increasing over time, meaning that the expansion of the universe is accelerating at a faster rate as time goes on.
9K
