Acceleration of wedges and particles
In summary, the problem involves a wedge with smooth faces resting on a smooth horizontal table, with particles of mass m placed on each face. The faces make angles A and B with the table, where tan A = 4/3 and tan B = 3/4. The goal is to show that the wedge will not move with a mass of 2m. By setting up equations for the forces and accelerations of each particle separately, it is shown that the wedge will remain stationary. This can also be shown by considering the forces normal to the surface, where there is no acceleration of the particle.
Woolyabyss
143
A wedge, all of whose faces are smooth, resting on a smooth horizontal table.Its faces make an angle A and B with the table, where tan A = 4/3 and tan b =3/4 .Particles of each of mass m are placed on these faces.If the mass of the wedge is 2m, show that the wedge will not move
F = MA
I tried to make equations for both particles seperately
first particle
tan A = 4/3
forces and acceleration of particle resolved into components
parallel = mg(4/5) perpendicular = mg(3/5)
parallel = a(3/5) perpendicular = a(4/5)
a = acceleration of wedge
f= acceleration of particle relative to wedge
R1=normal force
equations
(4/5)mg = m(f - (3a/5) ).... simplify 4g = 5f - 3a (I didn't use this equation)
3/5)mg - R1 = 4ma/5 ..... simplify 3mg - 5R1 = 4ma
Forces and acceleration of the wedge along horizontal
R1(sinA)... (4/5)R1 = 2ma simplify R1 = (10/4)ma
putting value for R1 into second equation 3mg - (50/4)ma = 4ma
simplify a = (2/11)g
Second particle
tan B = 3/4
parallel = (3/5)mg perpendicular = (4/5)mg
parallel = (4/5)b perpendicular = (3/5)b
b = acceleration of wedge
e = acceleration of particle relative to wedge
R2 =normal force
equations
(3/5)mg = m(e - 4b/5 ) (I didnt use this equation)
(4/5)mg - R2 = (3/5)b simplify 4mg - 5R2 = 3mb
Acceleration of wedge along the horizontal
R2(sinB) R2(3/5) = 2mb ... R2= (10/3)mb
put R2 into second equation
4mg - (50/3)mb = 3mb ...multiply by 3... 12mg = 50mb + 9mb
59b = 12g b = (12/59)g
a-b = (2/11)g - (12/59)g is not zero
I had no problem with these questions when there was only one particle on the wedge.Now that there is two particles I am not sure how to solve them. Should I have tried to make equations including both the particles instead of trying to solve both seperately? Any help would be appreciated.
Since you are only required to show that the wedge remains still, rather than calculate an acceleration, I feel it would be simpler to suppose another force F is applied to the wedge to hold it still then calculate F (and show it is 0). That avoids getting tangled up in relative accelerations.
Sorry I am not exactly sure how I can only take into account the forces without the acceleration?
I'm saying:
- suppose there is also a horizontal force F on the wedge sufficient to keep it still
- now you can assume the wedge is stationary, and figure out the forces on and accelerations of the two particles in the usual manner
- show that F=0
Would this be correct?
r1 and r2 are the normal forces of the particles
r1 = mg(cosa) = 3mg/5 and r2 = mg(cosb) =4mg/5
the forces acting on the wedge horizontally are F1 and F2
r1(sina) = 4r1/5 = (4/5)(3mg)/5) = 12mg/25 = F1
and the force in the opposite direction
r2(sinb) = 3r2/5 =(3/5)(4mg/5) = 12mg/25 = F2
Subtracting F1 and F2... 12mg/25 - 12mg/25 =0 N
Since the net force acting on the wedge horizontally equates to zero the wedge does not move.
That works for me.
Alright thanks for the help.
Sorry again but I just realized I might have made a mistake. Should
R1 = 3/5)mg - 4ma/5
and
R2 = (4/5)mg - (3/5)b
R1 = 3/5)mg - 4ma/5
and
You considered forces normal to the surface, right?
In the normal direction, there is no acceleration of the particle.
I got somebody to help me do it the way I originally tried(with the accelerations).
But thanks anyway
Related to Acceleration of wedges and particles
1. What is the definition of acceleration in regards to wedges and particles?
Acceleration is the rate of change of velocity over time. In the context of wedges and particles, it refers to how quickly the velocity of these objects changes as they move.
2. How is acceleration of a wedge or particle calculated?
The acceleration of a wedge or particle can be calculated by dividing the change in velocity by the change in time. This can be represented by the equation a = (vf - vi) / t, where a is acceleration, vf is final velocity, vi is initial velocity, and t is time.
3. What factors affect the acceleration of wedges and particles?
The acceleration of wedges and particles can be affected by various factors, including the force applied, the mass of the object, and any external forces such as friction or air resistance.
4. How does the angle of a wedge affect its acceleration?
The angle of a wedge can affect its acceleration by changing the direction and magnitude of the force applied to it. A steeper angle may result in a greater acceleration, while a shallower angle may result in a slower acceleration.
5. Can the acceleration of a wedge or particle ever be negative?
Yes, the acceleration of a wedge or particle can be negative if it is decelerating or slowing down. This can occur if there is a force acting in the opposite direction of its motion or if the object is moving in a circular path.
