Acceleration only due to conservation of angular momentum
In summary, the conservation of angular momentum can imply an acceleration in absence of a force, as seen in planetary motion. The angular momentum of the planets is conserved, meaning that the second term in the acceleration equation (r\ddot\theta+ 2\dot r \dot\theta) is zero. This is because the velocity in the direction of \hat{\boldsymbol{\theta}} is constant, due to the central force of gravity. However, if the distance r decreases, the velocity in the direction of \hat{\boldsymbol{\theta}} must increase in order to keep the angular momentum constant. This increase in velocity does not require a force, as it happens due to the conservation of angular momentum.
Soren4
128
I don't understand why the conservation of angular momentum can imply an acceleration, in absence of a force.
Consider for istance planetary motion. The angular momentum [itex]\vec{L}[/itex] of the planets is conserved and that means [itex]\mid \vec{L} \mid=mr^2 \dot{\theta}=mrv_{\theta}[/itex] is conserved too.
Consider the acceleration in polar coordinates
\left( \ddot r - r\dot\theta^2 \right) \hat{\mathbf r} + \left( r\ddot\theta+ 2\dot r \dot\theta\right) \hat{\boldsymbol{\theta}} \ $$
The second term is zero since [itex]\vec{L}[/itex] is constant. In fact the second term can be rewritten as [itex]
a_{\theta}=\frac{1}{r}[\frac{d}{dt}(r^2 \dot{\theta})]=\frac{1}{r}[\frac{d}{dt}(\frac{L}{m})][/itex].
This means that there is no acceleration in the direction of [itex] \hat{\boldsymbol{\theta}} [/itex], which is clear since the gravitational force is a central froce.
But if the distance [itex]r[/itex] decreases [itex]v_{\theta}[/itex] (i.e. the velocity in the direction of [itex] \hat{\boldsymbol{\theta}} [/itex]) must increase in order to keep [itex]\mid\vec{L} \mid[/itex] constant.
How can [itex]v_{\theta}[/itex] increase if there is no acceleration in the direction of [itex] \hat{\boldsymbol{\theta}} [/itex]?
I understood that it happens because of the conservation of angular momentum but if there is an acceleration, necessarily a force is needed. I don't see where do this force come from.
Speed changes because the force is not perpedicular to velocity, when the distance changess.
FAQ: Acceleration only due to conservation of angular momentum
1. What is the conservation of angular momentum?
The conservation of angular momentum is a fundamental principle in physics which states that the total angular momentum of a system remains constant in the absence of external torques.
2. How does acceleration relate to conservation of angular momentum?
Acceleration is a measure of the change in velocity over time. In the case of conservation of angular momentum, any changes in the angular momentum of a system are caused by an external torque, resulting in an acceleration.
3. Can an object accelerate solely due to conservation of angular momentum?
Yes, it is possible for an object to accelerate solely due to conservation of angular momentum. This occurs when there is no external torque acting on the object, causing its angular momentum to remain constant and resulting in an acceleration.
4. How is angular momentum conserved in a system?
Angular momentum is conserved in a system when the sum of the angular momenta of all objects within the system remains constant. This can occur through the transfer of angular momentum between objects or through the absence of external torques.
5. What are some real-life examples of acceleration due to conservation of angular momentum?
One example is a spinning top. As the top spins, its angular momentum remains constant, but as it starts to tilt or wobble, external torques cause it to accelerate in order to maintain its angular momentum. Another example is a planet orbiting around a star, where the planet's angular momentum remains constant due to the absence of external torques, resulting in a consistent acceleration in its orbit.
