kholdstare121
- 10
acceleration: screwed up vector??
I need things cleared up when it comes to acceleration.
Is acceleration negative when it points in a certain direction...or when an object is slowing down?
I was working on a free falling bodies word problem:
A diver springs upward with an initial speed of 1.8 m/s from a 3.0-m board.
(a) find the velocity with which he strikes the water.[Hint: when the diver reaches the water, his displacement is y=-3.0 meters (measured from the board), assuming that the downward direction is chosen as the negative direction.]
(b) What is the highest point he reaches above the water?
I can get the final velocity from part (a) alright,
To find the distance he jumps up, if I use a positive acceleration in the equation:
Vf^2=Vi^2+2ad
then I get a negative distance...which I shouldn't if he's traveling UPWARD as he jumps.
I use the same equation to get the final velocity as he hits the water:
Vf^2=vi^2+2ad
and I used both a negative displacement vector(-3.17m) and a negative acceleration vector(-9.8 m/s^2) and got + or - 7.9 m/s as the answer(I used the minus one, and it was the right answer)
but my question is: when is acceleration negative?
Thanks![Smile :smile: :smile:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Vf^2=Vi^2+2ad
Vf^2=vi^2+2ad
Thanks
