Acceleration vs Gravity in General Relativity
In summary, the conversation discusses the equivalence principle in general relativity, which states that the effects of gravity are equivalent to those of acceleration in a small region of spacetime. The example of a person in an elevator with an acceleration equal to the gravity of the Earth is often used to explain this principle, but it is not entirely accurate. This is because the principle only holds true locally, and with extremely precise measurements, one can distinguish between being on the Earth's surface and in an accelerating elevator. The concept of "local" refers to a small enough region of spacetime where the effects of gravity and acceleration are indistinguishable.
bgq
162
Hi,
It is usually claimed that a person in an accelerating elevator with an acceleration equals to the gravity of the earth; this person cannot make any experiment that makes him know whether he is in the elevator or on the surface of earth.
However, if this person project two light beams vertically downward and perform extremely accurate measurements, then he can predict whether he is on the Earth or in an accelerating elevator as follows:
If the light beams converge a little bit, then he is on the surface of the earth. If they don't converge then he is in an accelerating elevator. Consequently, the two situations are not identical.
I totally understand that the strength of general relativity is because it passes a lot of other tests, but what surprised me is that this example is always presented although it looks to me as not accurate.
Am I missing something?
Thanks in advance.
No. You are correct that the equivalence principle is only true locally. See, for example, the diagrams on pages 98 and 99 in Carroll's GR lecture notes (the second and third pages of this PDF: https://preposterousuniverse.com/wp-content/uploads/grnotes-four.pdf) which illustrate pretty much the example you are talking about.
The definition of "local" in this case is a small enough region of spacetime that you don't notice this kind of effect (with whatever degree of precision you are measuring).
Likes bgq
Thank you very much.
Related to Acceleration vs Gravity in General Relativity
1. What is the difference between acceleration and gravity in General Relativity?
In General Relativity, acceleration and gravity are essentially the same thing. According to Einstein's theory, gravity is the result of the curvature of spacetime, and objects experience this curvature as acceleration.
2. How does General Relativity explain the motion of objects in a gravitational field?
In General Relativity, the presence of a massive object (such as a planet or star) causes a curvature in spacetime. This curvature affects the motion of objects, causing them to follow a curved path towards the source of gravity.
3. Is the acceleration due to gravity constant in General Relativity?
No, the acceleration due to gravity is not constant in General Relativity. Unlike in Newtonian physics, where gravity is considered a force that acts at a distance, in General Relativity gravity is a result of the curvature of spacetime. This curvature can vary depending on the mass and energy distribution in the universe, leading to varying levels of acceleration.
4. Can General Relativity explain the behavior of objects in extreme gravitational fields?
Yes, General Relativity has been successful in explaining the behavior of objects in extreme gravitational fields, such as those near black holes. In these extreme conditions, the curvature of spacetime is so strong that it can cause extreme effects such as time dilation and gravitational lensing.
5. How does General Relativity differ from Newtonian physics in its explanation of gravity?
In Newtonian physics, gravity is considered a force that acts at a distance between two objects with mass. General Relativity, on the other hand, explains gravity as a result of the curvature of spacetime caused by the presence of mass and energy. This theory also accounts for the effects of gravity on the fabric of spacetime itself, which leads to phenomena such as the bending of light and the slowing of time in strong gravitational fields.
