Acceleration with position given
In summary, the question asks for the magnitude of an object's acceleration given its position function. The attempt at a solution involved finding the velocity using the x and y coordinates, but this only gives the average velocity. To find the acceleration at any point, differentiation is necessary.
silentsaber
The position of an object is given by r(t) = 4 cos(3t) i + 4 sin(3t) j (where distance is
in meters and time is in seconds). What is the magnitude of the object’s acceleration at
any given point in time?
v=x/t a=v/t
ok so i thoguht that since the x and y coordinates are 4 cos 3t and 4 sin 3t the hypotenuse would be 4 and then that would be the distance so then i solved for t by 4cos(3t)^2 + 4sin 3t^2=4^2 and i solved t to be 30 since sin of 3(30)=90 is 1 and cos of 90 is 0 then i used the 30 as my time and divided 4/30 to find the velocity and then use the velocity and plugged it in v/t and i get the wrong answer...where did i go wrong?
v = x / t only gives you the average (which is exact, whenever the acceleration is zero).
If you want the acceleration at any point in time, you need to differentiate.
v(t) = r'(t)
a(t) = v'(t) = r''(t)
where the prime denotes differentiation with respect to time.
Hello,
Your attempt at a solution is on the right track, but there are a few errors in your calculations. Firstly, the hypotenuse of the triangle formed by the x and y coordinates is not always 4. It varies depending on the value of t. To find the magnitude of acceleration, we need to use the equation a = v/t, where v is the velocity and t is the time.
To find the velocity, we can take the derivative of the position function r(t). This will give us the velocity function v(t). So, v(t) = -12 sin(3t) i + 12 cos(3t) j. Now, we can plug in the value of t (30 seconds) to find the velocity at that point. However, note that the velocity is a vector quantity, so we need to find the magnitude of this vector using the Pythagorean theorem.
Once we have the magnitude of velocity, we can divide it by the time (30 seconds) to find the acceleration at that point. This will give us the correct answer.
I hope this helps! Let me know if you have any further questions.
FAQ: Acceleration with position given
What is acceleration with position given?
Acceleration with position given refers to the change in velocity of an object over a specific position or distance. It is a measure of how quickly an object's speed and direction are changing.
How is acceleration with position given calculated?
Acceleration with position given can be calculated by dividing the change in velocity by the change in position. This is represented by the equation a = (vf - vi) / (xf - xi), where a is acceleration, vf is final velocity, vi is initial velocity, xf is final position, and xi is initial position.
What is the unit of measurement for acceleration with position given?
The unit of measurement for acceleration with position given is meters per second squared (m/s^2).
How does acceleration with position given differ from average acceleration?
Acceleration with position given is a measure of the instantaneous acceleration of an object at a specific position, while average acceleration is the overall change in velocity over a given period of time. Average acceleration takes into account the starting and ending velocities, while acceleration with position given only considers the velocity at a specific position.
What are some real-life examples of acceleration with position given?
Some real-life examples of acceleration with position given include a car's acceleration as it travels along a curved road, a roller coaster's acceleration at different points along the track, and a person's acceleration as they jump off a diving board into a pool.
