MHB According to Buckingham Theorem the rank of A should be 2
  • Thread starter Thread starter evinda
    rank Theorem
The discussion revolves around applying the Buckingham Theorem to a physical system described by the equation f(E,P,A)=0, where E, P, and A represent energy, pressure, and surface area, respectively. Participants clarify that the rank of the associated matrix A is 2, indicating there are two linearly independent column vectors. The confusion between the concepts of "rank" and "order" is addressed, with rank defined as the dimension of the matrix's range. The conversation concludes with confirmation that specific vectors can indeed span the vector space of the matrix. Understanding these concepts is crucial for deriving dimensionless quantities from the physical law.
evinda
MHB
Hello! (Wave)
A physical system is described by a law of the form $f(E,P,A)=0$, where $E,P,A$ represent, respectively, energy, pressure and surface area. Find an equivalent physical law that relates suitable dimensionless quantities.
That' what I have tried so far:
1st step:
Choice of quantities
Mass: $M$
Time: $T$
Length: $L$
So:
$$[E]=M L^2 T^{-2}$$
$$[P]=ML^{-1}T^{-2}$$
$$[A]=L^2$$2nd step:
Construction of dimonsionless quantities
The matrix of dimensions:$A=\begin{bmatrix}
1 & 1 & 0\\
-2 & -2 & 0 \\
2 & -1 &2
\end{bmatrix}$I tried to find the rank, determining the smallest $n$ for which $A^n=I$.$\begin{bmatrix}
1 & 1 & 0\\
-2 & -2 & 0 \\
2 & -1 &2
\end{bmatrix}\begin{bmatrix}
1 & 1 & 0\\
-2 & -2 & 0 \\
2 & -1 &2
\end{bmatrix}=\begin{bmatrix}
-1 & -1 & 0\\
2 & 2 & 0 \\
8 & 2 &4
\end{bmatrix}$$\begin{bmatrix}
-1 & -1 & 0\\
2 & 2 & 0 \\
8 & 2 &4
1 & 1 & 0\\
-2 & -2 & 0 \\
2 & -1 &2
1 & 1 & 0\\
-2 & -2 & 0 \\
12 & 0 &8
\end{bmatrix}$But I saw the solution and there should be only one dimensionless quantity, so according to Buckingham Theorem the rank of $A$ should be $2$.
Where is my mistake? (Thinking)
Mathematics news on Phys.org
Hey! (Smile)
Isn't that the order of $A$ instead of the rank of $A$? (Wondering)
The rank of $A$ is indeed $2$.
What is the difference between order and rank? (Thinking)
Because of the fact that there are two linearly dependent rows? (Thinking)
In algebra the order of an element $a$ is the lowest power $n$ such that $a^n=id$.
The rank of a matrix is the dimension of its range. (Nerd)
Yes. (Nod)
More specifically, there are 2 linearly independent column vectors.
The range of the matrix is the span of those 2 vectors, meaning that range has dimension 2. (Emo)
A ok... (Nod)
I like Serena said:
Yes. (Nod)
So could we say that the following two vectors
$\begin{pmatrix}
1\\
-2\\
-1
\end{pmatrix} , \begin{pmatrix}
0\\
0\\
\end{pmatrix}$ span the vector space of the matrix? (Thinking)
$\begin{pmatrix}
1\\
-2\\
-1
0\\
0\\
Yes. (Nod)
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
