Accurate, precise, both, or neither?
  • Thread starter Lori
In summary, the student measured 1.9584 as the density of water in three trials, with values ranging from 1.9141 to 1.8991. It is not considered precise as the values differ by more than 0.01 and it is not accurate unless the specification is to have two decimal places of accuracy.
Lori
1.9584 is the measured density of water...
student measures 3 trials:
1. 1.9141
2. 1.9584
3.1.8991
Precise - the closeness of the measurements to each other
accuracy- the closenses of measures to the actual value
I'm thinking it's neither precise or accurate. The values are not close to 1.9583, they differ quite different given that the actual measured values have more decimal places.
Also, it wouldn't be precise because they all different greater than 0.01
Depends on your standards, but a 0.5% precision shouldn't be too hard, yes.
What is their mean? How much does that differ from the precise value, if you consider the spread of the measurements?
mfb said:
Depends on your standards, but a 0.5% precision shouldn't be too hard, yes.What is their mean? How much does that differ from the precise value, if you consider the spread of the measurements?
the mean is 1.9239 which is like 0.03 away from the actual measurement. Would this make it accurate?
It is not sufficient to tell if many measurements would have the right average or not.
Define "accurate" !
If the specification is that you need accuracy to two decimal places, then yes. If you need it to 8 decimal places, then no.
Just as an aside, and not because I think you don't understand the difference between precision and accuracy, this is how I was taught to remember the difference.
How do you get from Washington DC to the middle of Texas?
Precise answer: <long set of very detailed directions that ends you up somewhere near Boston.>
Accurate answer: Go to Oklahoma and turn left.​
I wasnt sure of the answer because it was multiple choice. So, i just picked neither precise or accurate
Related to Accurate, precise, both, or neither?
1. What is the difference between accuracy and precision?
Accuracy refers to how close a measurement or value is to the true or expected value. Precision, on the other hand, refers to how close a set of measurements are to each other. In other words, accuracy is about correctness while precision is about consistency.
2. Can something be accurate but not precise, or vice versa?
Yes, something can be accurate but not precise. For example, if a dart thrower consistently hits the same spot on the dart board, even though it may not be the center, the throws are precise but not accurate. Vice versa, something can be precise but not accurate if it consistently misses the target in the same way.
3. How are accuracy and precision measured?
Accuracy is measured by comparing a measurement or value to the true or expected value using a standard. Precision is measured by calculating the variation among a set of measurements using statistics such as standard deviation.
4. Is it better to have accuracy or precision?
It depends on the context and the purpose of the measurement. In some cases, accuracy may be more important, such as in medical or scientific experiments. In other cases, precision may be more important, such as in manufacturing processes.
5. Can something be both accurate and precise?
Yes, something can be both accurate and precise. For example, if a dart thrower consistently hits the center of the dart board, the throws are both accurate and precise.
