Aceleration & tension in a system involving pulley
The discussion focuses on understanding the effects of a frictionless pulley on the acceleration and tension in a system involving two masses. The user is trying to apply Newton's second law and free body diagrams to analyze the forces acting on the masses and the pulley. It is noted that the pulley experiences different tensions on either side, leading to an unbalanced torque that affects its rotation. The tension in the system is influenced by the frictional force acting on one mass and the weight of the other mass. Incorporating the pulley into the equations is essential for accurately determining the system's overall acceleration.
jb007
1. Homework Statement
I am stuck on this problem involving tension, acceleration of a system, friction and a pulley. I have an idea of how to find the acceleration of the system neglecting the mass of the pulley, but it is not the solution. How does adding a frictionless pulley in the system change its acceleration?
F=ma
torque = I(alpha)
rotational equations?
For the tension T1 from the pulley disk downwards to mass m, the tension is mg.
For the tension T2 from the mass M rightward to the pulley disk, would the tension be equal to T1?
I drew FBD's for the two masses.
For M, by applying Newton's 2nd Law, Fnet=Ma: T2-f = Ma
For m, applying F=ma: mg-T1 = ma
I know the acceleration of the system should be equal. But how do I incorporate the pulley disk in the system to find the acceleration of the system?
[/B]
You draw free body diagrams for both blocks and the pulley ... hint: what sort of motion does the pulley undergo?
So the pulley disk is rotating. The string wraps around the top of the disk, and it rotates in the same direction as the acceleration of the two blocks (the same way the string is moving). Would this be a torque force acting on pulley disk? Because the force on the disk by the string is perpendicular to the radius?
The disk must be accelerating (unless the rope is slipping) so there must be an unbalanced torque in the direction of the acceleration.
The free body diagram for the pulley has two forces on it - from each straight section of string.
The forces produce opposing torques. The tension on either side of the pulley will be different.
So the tension on the left side of the pulley would be the tension caused by the frictional force acting on M, and the tension on the right side of the pulley would be caused by the weight of m? (They are in opposite directions)
As far as the free body diagram of the pulley is concerned, there is no mass m or mass M.
Just write in T1 and T2 for the two tensions ... they come from the interactions between parts of the overall system.
  • · Replies 22 ·
  • · Replies 26 ·
  • · Replies 27 ·
  • · Replies 18 ·
  • · Replies 30 ·
  • · Replies 102 ·
  • · Replies 40 ·
  • · Replies 38 ·
