Acetanilide produces one molecule of hydroge bromide
  • Thread starter nemzy
  • Tags
    Molecule
In summary, one molecule of acetanilide will produce one molecule of hydrogen bromide, which has a mass of 82 grams.
nemzy
125
If each molecule of acetanilide produces one molecule of hydroge bromide, what volume of HBr gas should be evolved from the reaction?
So to solve this, ONE molecule of acetanlide will produce ONE molecule of hydrogen bromide...
then, the molecular weight of hydrogen bromide produced will have a mass of 82 grams...
Ok, am i doing this problem correctly so far?
So what step do i have to go to next, i am confused on how to approach this problem, thanks
Chemistry news on Phys.org
You must know the starting amount of acetanilide, that is, the mole amount. 1:1 ratio will give that moles of HBr after the reaction is completed.
Note that the molecular weight is 82 grams/mol, so just one molecule is only 82 amu (atomic mass unit). Don't use grams when dealing with atoms, molecules, etc, without multiplying them with Avogadro's number.
Since you want to know the volume, you need not even care about the molecular or molar weight of HBr, as you can relate the amount of gas molecules directly to the volume they demand. At room temperature the molar volume is 24,0 dm3/mol I think, or was it 22,4 at room temperature and 24,0 at some other? PV=nRT (OK actually only for ideal gases but it normally holds fairly well in order to use it for real gases) so V_molar = V/n = R*T/P = 8,31 J/K * 298 K (oh, 25 deg celsius is warm to me but I think it is called room temperature) / 1 atm (and convert atm to N/m2 = Nm/m3 = J/m3).
OK, say you have 1 g of acetanilide (dunno the substance), and just hypothetically (but totally non-physically) it has molar mass 2 g/mol (yeah, as I said non-physical, it should of course be more, but I just pick a figure that is ez to count with).
1 g / (2 g/mol) = 0,5 mol, which (if the "ONE to ONE" assumption is correct) is the amount of HBr produced.
0,5 moles of HBr use 0,5 mol * 24 dm3/mol = 12 dm3 = 12 Litres
Is this the answer to your question? No, I guess you have some more reasonable numbers to put into the equations. And moreover, as chem_rt noted, you didn't state the starting quantity, nor the type of quantity to start with (volume? mass? it almost sounds like part of a larger problem where you should have calculated some quantity already)
Hope this helps!
Keep up the hard work :wink:
FAQ: Acetanilide produces one molecule of hydroge bromide
What is Acetanilide?
Acetanilide is a synthetic organic compound that is commonly used in the production of pharmaceutical products. It is also known as N-phenylacetamide and has a molecular formula of C8H9NO.
How does Acetanilide produce hydroge bromide?
When Acetanilide is heated with hydrobromic acid, a chemical reaction occurs that results in the formation of one molecule of hydroge bromide. This reaction is known as an acid-catalyzed hydrolysis reaction.
What is the purpose of hydroge bromide in this reaction?
Hydroge bromide acts as a catalyst in the reaction between Acetanilide and hydrobromic acid. It helps to speed up the reaction and increase the yield of the desired product.
What are the potential uses of Acetanilide?
Acetanilide has various uses in the pharmaceutical industry, including as a precursor for the production of other drugs such as paracetamol. It is also used in the production of dyes, plastics, and rubber chemicals.
Is Acetanilide safe to handle?
Acetanilide is considered to be relatively safe to handle, but it can be hazardous if ingested or inhaled in large amounts. It is important to follow proper safety precautions when handling this compound, such as wearing protective gear and working in a well-ventilated area.
