awiltz2
- 1
I was reading about dentist drills, and I discovered an amazing piece of trivia about them: modern dentist drills spin at 400,000 revolutions per minute (over 6666 times per second!).
So I thought, if this was spinning a large wheel, whose outer rim would rotate at a rate progressively faster than the inner rims, could it ever achieve the speed of light? Technically, I know that the speed of light (c) is a physical limit, but what would happen to such a physical device?
So you have an axle run by a powerful motor that rotates the wheel it is attached to at a rate of 6666 revolutions per second (speed of dentist drill).
Speed of light (c) is ~300,000,000 meters per second. At 6666rpm, to achieve the speed of light we would need a wheel whose circumference is (300,000,000 / 6666) 45,000 meters, which would equate to a diameter of (45,000 / pi) 14,324 meters - roughly 9 miles.
So we create a structurally-sound, 9-mile-wide wheel and rotate it on an axle, slowly but surely until we achieve 6666rpm.
To run the motor would require an almost unimaginable amount of energy (I reckon), and to find enough material to create a wheel that is structurally sound enough to not fall apart in the process would most likely be inconceivable, but ...
If we could capture enough energy, and obtain the necessary materials, could this work? If not, why not? Something tells me that the laws of physics somehow prevent the physical integrity necessary for such a wheel, but this is simply a guess.
Andrew
Andrew
