Acidity due to ortho effect in benzene
  • Thread starter Tony Stark
  • Tags
    Benzene
In summary: Ortho-substituted benzoic acids are more acidic than para-substituted benzoic acids because of the steric hindrance caused by the ortho group.
Tony Stark
51
Acidity increases with resonance, but why under the presence of bulky group attached to benzene in ortho position increase acidity ?
Under such cases, the planarity is broken and resonance is no longer possible between attached group and benzene hence the charges have to maintain their original position decreasing acidity of the compound ?
Chemistry news on Phys.org
I'm assuming you mean Lewis acid.
I took this to mean, e.g., why is o-toluic acid more acidic than m-toluic acid or p-toluic acid? It's a phenomenon typically referred to as the ortho effect. So a couple of things are wrong: acidity can increase with resonance, but there are also other factors at play. Typically, the factor that most determines acidity is the stability of the conjugate base. So the more stable the deprotonated species is, the more acidic the protonated species will be. In the case of benzoic acid, the benzene ring pushes electron density onto the carboxyl group. The easiest way to see this is to compare the pKa's of formic acid (3.7) and benzoic acid (4.2), since formic acid is about as close as we can get to "nothing" as a substituent on the carboxyl group. In the bare benzoic acid (or in m- or p- substituted benzoic acids) the benzene ring and carboxyl group are aligned in the same plane. The benzene ring can then donate electrons onto the highly electronegative carboxyl group. This strengthens the bond between the carboxyl O and the acidic proton, rendering the compound less acidic (if the benzene were instead electron-withdrawing, the resulting compound would be more acidic). In the case of ortho-substituted benzoic acid, this planarity is broken by steric hindrance. The electron-donating effect of the benzene ring is reduced or absent, and the compound is therefore more acidic.
This is the standard textbook explanation of the ortho effect, and I'll be the first to admit that it seems a little wishy washy to me. For instance, in most cases meta-substituted benzoic acids are more acidic than para-substituted ones, which can't be explained by a steric effect (the order of acidity being o > m > p). However, we know that the phenomenon is relatively independent of whether the ortho group is electron donating or electron withdrawing, which seems to point away from an inductive effect. It seems like a good area for a research project.
What's hard to understand? More electron density makes it harder to pull off the acidic proton. If steric hinderance distorts planarity, then resonance is broken up, and there is less electron density on the carboxyl group, making it easier to ionize. You should have mentioned substituted benzoic acids in your OP.
Related to Acidity due to ortho effect in benzene
1. What is the ortho effect in benzene?
The ortho effect in benzene refers to the increase in acidity of a compound when a substituent is attached to the ortho position (directly adjacent) of a benzene ring. This is due to the destabilizing effect of the substituent on the benzene ring, making it easier for the molecule to release a proton and become acidic.
2. How does the ortho effect affect the acidity of a compound?
The ortho effect increases the acidity of a compound by destabilizing the benzene ring and making it easier for the molecule to release a proton. This is because the substituent attached to the ortho position can donate electron density to the benzene ring, making it more electron-rich and therefore more acidic.
3. Why is the ortho effect more pronounced in benzene?
The ortho effect is more pronounced in benzene because the benzene ring is a highly conjugated system. This means that the electrons in the ring are delocalized and can be easily influenced by substituents attached to the ortho position, resulting in a greater destabilizing effect on the ring and an increase in acidity.
4. What types of substituents can cause the ortho effect in benzene?
Substituents that are electron-donating, such as alkyl groups, can cause the ortho effect in benzene. This is because they donate electron density to the benzene ring, making it more electron-rich and therefore more acidic. Examples of such substituents include methyl, ethyl, and tert-butyl groups.
5. How does the ortho effect impact the reactivity of a compound?
The ortho effect can impact the reactivity of a compound by making it more acidic, which can lead to different chemical reactions. For example, in an electrophilic aromatic substitution reaction, the ortho effect can increase the rate of reaction by making the compound more susceptible to attack by electrophiles due to its increased acidity.
  • Mechanics
