MHB ACT Problem: Determine Constant In Polynomial Given Factor
To determine the constant z in the polynomial 2x^2 - 4x - z, given that (x-4) is a factor, we set f(4) = 0. Substituting x = 4 into the polynomial yields the equation 32 - 16 - z = 0. Simplifying this leads to 16 - z = 0, which results in z = 16. Therefore, the value of z is 16. This method effectively uses the factor theorem to solve for the constant.
816318
Assume that (x-4) is a factor of 2x^2-4x-z. What is the value of z?
How would you set it up to use the foil method?
Mathematics news on Phys.org
Re: ACT problem
Let:
$$f(x)=2x^2-4x-z$$
Now, if $x-4$ is a factor of $f$, then we must have:
$$f(4)=0$$
So, this allows us to write:
$$2(4)^2-4(4)-z=0$$
Can you proceed?
Re: ACT problem
MarkFL said:
Let:
$$f(x)=2x^2-4x-z$$
$$f(4)=0$$
$$2(4)^2-4(4)-z=0$$
Can you proceed?
32-16-z+=0; 16-z=0; 16=z
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
