I Action in Lagrangian Mechanics
Lagrangian mechanics relies on the calculus of variations to determine the action, defined as an integral that needs to be minimized or maximized. The integral typically involves variables like time, potential energy, or distance, which are crucial for solving problems such as the brachistochrone or catenary problems. The Euler-Lagrange equation is then used to derive equations of motion from the defined Lagrangian, which is the difference between kinetic and potential energy. The discussion highlights the historical development of the principle of least action, emphasizing the foundational roles of Newton and Hamilton in formulating these concepts. Understanding the principle of least action is essential for grasping the underlying mechanics of motion.
Dario56
Lagrangian mechanics is built upon calculus of variation. This means that we want to find out function which is a stationary point of particular function (functional) which in Lagrangian mechanics is called the action.
To know what this function is, action needs to be defined first. Action is defined via integral.
In problems which use calculus of variation such as brachistochrone problem, caternary problem or finding path of least distance between two points, appropriate integral is the integral between two points of question of appropriate variable (time, potential energy, distance etc.), that is the integral of variable which is usually needed to be minimized in the problem (can be maximized as well).
When integral is defined, function is known and with Euler - Lagrange equation we get the solution to the problem. For example that can be function which defines path of least time, distance or shape of the rope as a solution of caternary problem.
What I don't understand is how to define this integral in context of Lagrangian mechanics or in context of action? In another words, how did Lagrange found out that difference in kinetic and potential energy of the system (commonly known as Lagrangian) gives correct equations of motion when plugged in Euler - Lagrange equation?
Wikipedia has a page on the history and development of the principle of least action:
https://en.wikipedia.org/wiki/Stationary-action_principle
Probably similar to this
You might try looking at Lanczos
https://www.amazon.com/dp/0486650677/?tag=pfamazon01-20
Rojo and Bloch
https://www.amazon.com/dp/0521869021/?tag=pfamazon01-20
Coopersmith
https://www.amazon.com/dp/0198743041/?tag=pfamazon01-20
  • Haha
Likes Dario56 and vanhees71
You don't need lagrange, you need Newton+hamilton+idea of test particle. We, as physicists, use test particles to learn about the behavior and motion about the world around us.
Newton's first law is basically "test particles, when left alone, will move in a straight line at a constant speed".
Then a guy called Hamilton sets up a premise called "principle of least action" which uses Newton's ideal+geometry, in which you must notice that a straight line between two points can be thought of as "the shortest distance" or "least time" between two points. If you agree with this, then bam, you formulate the following integral formulation:
$$S =-mc \int^{\tau_{final}}_{\tau_{initial}} d \tau$$
Minimizing this for some $\tau$ will give you the trajectory of a free particle. There is more to this story, and I hand waved a little, but I believe your question isn't really with lagrange, but more so with hamilton, Newton, and the ideal of a test particle, and at the core, what IS a principle of least action?!
Now, I've never TRULY gotten classical mechanics because it never sat right with me, but if the above is what you're questioning, I'm sure Feynman can do a better (and more through) job than I can, and you can find more information here:
https://www.feynmanlectures.caltech.edu/II_19.html
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
