Action Potential Through Ion Channel, Total Number of Ions Through
In summary, a single ion channel with a resistance of 1GOhm can allow 4.68E4 potassium ions to pass through during an action potential of 90mV.
Bluestribute
194
Nerve signals in the body occur when a small voltage, called an action potential, is applied across the membrane of a cell. When this action potential is applied across a region of the cell membrane called an ion channel, current in the form of moving potassium ions will be established across the cell. If, during an action potential of 90 mV, a single ion channel with a resistance of 1 G[PLAIN]http://loncapa.mines.edu/adm/jsMath/fonts/cmr10/alpha/100/char0A.png, is opened for 1[PLAIN]http://loncapa.mines.edu/adm/jsMath/fonts/cmmi10/alpha/100/char3A.png2 ms, approximately how many singly-ionized potassium ions travel through the channel during this time?
I = n*q*Vd*A
I first converted 90mV to 90E-3V.
Then I convert 1GOhm to 1E9 Ohm.
Then I converted 1.2 ms to .0012 s.
I'm assuming I'm solving for "n" in the equation, so did V/R to find I (90E-3/1E9)
I divided that by the fundamental charge, 1.602E-19 (*note, I also used simply a "1" here with no luck either) times time.
I got 4.68E4, and other multitudes of 10, as my answer with no luck. And it's a practice exam so I shouldn't have to google anything (i.e. the area of an ion channel?).
I also tried using J=n*q*Vd and J=0.5*Q/V, making the assumption my Q's could cancel. No cigar.
Ever heard of Ohm's law ?
Yep. And I=V/R is not the amount of ions through a channel
Nope, it isn't. But there is a very simple relation between charge and current.
Q = I*t (after googling).
I don't understand how this helps at all figuring out how many ions have gone through the channel . . .
There is also a charge per singly-ionized potassium ion, call it e. total charge Q, one each has e, so their number is ...
Voila!
Likes Greg Bernhardt
I tried Q = I*t, (I*t)/1.602E-19 (fundamental charge). Nope.
Nope what ? Show your steps so I don't need telepathy.
Oh, sorry. The steps are there. I get something else, so checking might get you off the hook.
[edit] Yes, definitely. 9*1.2/1.6 should be closer to 7 than to 5. And you seem to prefer hosing the target over sharp-shooting, so the power of 10 is a matter of 1,2,3,4,5,6,7,8,...;)
I ran out of tries and switched my numbers: 85mV, 1.3GOhms,0.6ms
Q = I*t = (V/R)*t = 6.54E-11*0.0006 = 3.92E-14 => 3.92E-14/1.602E-19 = 244886.
Now when I did this with my previous numbers, I did NOT get the correct answer (despite the same exact method). Before my numbers have been convenient despite my formula being wrong. I can't tell if this is the same case. If my numbers were just convenient though my method wrong.
A lot of digits for a single/two digit set of givens. I get 2.45e5 too. Previously I had 6.7e5.
So that is the correct way to solve a problem like that than? Use Q=I*t and Q/1.602E-12? And it was just a mis type into my calculator for the first set of numbers?
I'm learning the equivalent of all the lectures they forgot to present right now . . . Hooray . . .
I suppose so. Quite a lot of ions for such a small bit of nerve activity is what they try to teach us in this exercise.
Good luck! :-)
Thanks for the help. I just hate studying when they don't give us the proper tools to study with -__-
Most important tool is your brain. Common sense is equally important. And with experience in doing exercises you acquire some insight in the minds of those poor chaps who have to concoct them ..
FAQ: Action Potential Through Ion Channel, Total Number of Ions Through
What is an action potential?
An action potential is a brief electrical signal that travels down the axon of a neuron in response to a stimulus. It is the primary means of communication between neurons and allows for the transmission of information throughout the nervous system.
How is an action potential produced?
An action potential is produced when a stimulus causes a sudden influx of positively charged ions, such as sodium, into the neuron. This causes a change in the electrical potential of the cell, resulting in the initiation of an action potential.
What is an ion channel?
An ion channel is a protein structure embedded in the cell membrane that allows the passage of ions in and out of the cell. These channels are essential for the generation and propagation of action potentials.
How many ions are involved in an action potential?
The total number of ions involved in an action potential can vary depending on the type of neuron and the strength of the stimulus. However, on average, it is estimated that approximately 10,000 ions are involved in the process.
What role do ions play in an action potential?
Ions, specifically sodium and potassium, are crucial for the generation and propagation of an action potential. The movement of these ions across the cell membrane creates the electrical signal that allows for the transmission of information between neurons.
