Active burn control by using microwaves to control the detonation of the engine
In summary: How did microwave ignition the company get around this issue?By using a high power microwave transmitter and receiver, they can image the flame front as it starts to spread through the mix. By timing the emission of the microwaves to coincide with the arrival of the reflected radiation, they can get an image that is not affected by the echo from the metallic combustion chamber.
Andrewtv848
TL;DR Summary
using microwaves to control the detonation of the engine.
I was thinking the other day, would it be possible to have microwaves heat the air fuel mixture to activation point and have the microwaves bounce back off the gas to be picked up by a computer that generates a 3d image. this 3d image could be used to heat the gas up in a uniform way so as to control turbulence and increase volumetric efficiency. Go easy, I only have my high school diploma.
What happens to the gas after heating and the first 3D image? It rises like hot air from a campfire, and smears all subsequent images.
You didn't comment on the laser light shows. How is your 3D image different than those?
What kind of engine? What problem are you trying to solve (e.g., is this a known limitation?)?
Andrewtv848 said:
Summary:: using microwaves to control the detonation of the engine.
Whoops, I got this thread mixed up with another thread. Sorry.
Disregard post #2.
Imagine a microwave ignition system in a ICE that had the ability to use the return waves that bounce off the air fuel mixture to generate a 3d image. This data could be used to heat the air fuel mixture to a threshold degree based on density and hover on the diminishing returns that are how quickly you could ignite the AFM. optimizing the detonation right down to the the piston stroke. Hopefully achieving a higher thermal efficiency then a conventional microwave spark plug and all over the rev range. using directed energy to pin point the different pressures and size and shape of the AFM.
Would it be worthy of a patent?
[mod note: post moved to existing thread on the same subject]
Having compressed AFM ready to ignite limits the compression ratio and requires the ignition timing be accurately controlled. The detonation damages the engine by suddenly pushing the piston rings into the cylinder wall, and causing a step at the top of ring travel. The resulting taper breaks the rings.
You could get an improved economy by increasing the compression ratio. Fuel is then injected from a common rail system only when, and at the rate required. It is called a diesel engine.
I am unclear of the direction of your question. If you are suggesting fitting a microwave system to the engine to prevent knock, I would suggest it is far more expensive than conventional systems presently in use. Knock is a phenomenon connected with the growth in concentration of free radicals ahead of the flame front. Whether a pulse of microwave radiation would destroy these is a moot point.
Could you limit how much is ignited at once so you are not pounding the piston rings? How did microwave ignition the company get around this issue?
Common or garden microwaves are too long to image the thin flat cavity, so you would need far infrared wavelengths to construct an image. That image would show the flame front as it started to spread through the mix, but more because of the IR generated than because of the reflection from the flame front. The metallic combustion chamber would echo with reflected EM radiation, which would blot out any possible image.
No. Once initiated, the flame front propagates through the mixture and cannot be stopped. Since the valves are closed during the power stroke, the only way to control the rate of combustion is by direct injection of liquid fuel, through an atomiser, at the rate required.
I was unaware that such an engine was available. Do you have a link?
A microwave corona discharge should ignite the mixture in a similar way to a spark plug.
Likes Andrewtv848
Related to Active burn control by using microwaves to control the detonation of the engine
1. How does using microwaves control the detonation of the engine?
Microwaves are electromagnetic waves that can be used to control the combustion process in an engine. By targeting specific areas of the engine with microwaves, the temperature and pressure of the fuel-air mixture can be regulated, preventing detonation and ensuring a more efficient burn.
2. What are the benefits of using microwaves for active burn control?
Using microwaves for active burn control offers several advantages. It allows for precise control of the combustion process, leading to improved fuel efficiency and reduced emissions. It also allows for real-time adjustments, making it more adaptable to changing conditions.
3. Is using microwaves safe for the engine and surrounding components?
Yes, using microwaves for active burn control is safe for the engine and surrounding components. The microwaves are targeted and controlled, ensuring that they do not cause any damage or interference with other engine functions. Additionally, the levels of microwaves used for this purpose are well below the safety thresholds set by regulatory agencies.
4. Can this technology be applied to all types of engines?
While the concept of using microwaves for active burn control can be applied to most types of engines, the implementation may vary depending on the specific design and requirements of the engine. Further research and development are needed to optimize this technology for different types of engines.
5. Are there any limitations or challenges to using microwaves for active burn control?
One potential limitation of using microwaves for active burn control is the need for precise targeting and control, which may require advanced sensors and algorithms. Additionally, the size and weight of the equipment needed for this technology may be a challenge for smaller engines. Further research and development are needed to address these challenges and optimize the technology for practical use.
  • Optics
  • Mechanical Engineering
  • Aerospace Engineering
