Activity - Equilibrium Expressions
In summary, the concept of activity can be used to express the equilibrium constant expression, resulting in a unitless value for K. However, there is an exception to this principle when the sum of the powers in the numerator and denominator of the expression are equal, in which case Kc is equal to Kp. This is due to the difference in reference states, with Kc using a reference concentration of 1 mol/L and Kp using a reference pressure of 1 atm or 1 bar. Changing the reference pressure can affect the value of Kp by a factor of 2Δn, but if Δn is 0, the value of K remains independent of the reference pressure.
i_love_science
80
When I use the concept of activity to express the equilibrium constant expression, for either equilibrium pressures or concentrations, the units cancel and the value of K has no units (which is how K is customarily reported). But because of the difference in reference states (the reference pressure is 1 atm (or 1 bar) and the reference concentration is 1 mol/L), Kc is not equal to Kp.
Why is there an exception to this principle when the sum of the powers in the numerator and the denominator of the equilibrium expression are the same? Aren't the reference states still different? In this case Kc is equal to Kp. Thank you!
Chemistry news on Phys.org
Consider changing the reference pressure, say from 1 bar to 0.5 bar. Each reagent pressure (expressed as a multiple of the reference pressure) will increase by a factor of 2. The expression for Kp will therefore change by a factor 2Δn. If Δn = 0, the value of K is independent of the reference pressure.
Likes etotheipi, i_love_science and jim mcnamara
Thanks, I understand now.
Related to Activity - Equilibrium Expressions
1. What is an equilibrium expression?
An equilibrium expression is a mathematical representation of the ratio of products to reactants at equilibrium in a chemical reaction. It is written using the concentrations (or pressures) of the reactants and products, raised to the power of their respective stoichiometric coefficients.
2. How is an equilibrium expression different from a reaction quotient?
An equilibrium expression is calculated using the concentrations (or pressures) of the reactants and products at equilibrium, while a reaction quotient is calculated using the initial concentrations (or pressures) of the reactants and products. The equilibrium expression represents the equilibrium state of a reaction, while the reaction quotient represents any point in time during the reaction.
3. How do you determine the equilibrium constant from an equilibrium expression?
The equilibrium constant is determined by dividing the products of the equilibrium expression by the reactants. The numerical value of the equilibrium constant is determined by the temperature and is a measure of the extent to which the reaction proceeds towards products at equilibrium.
4. Can the equilibrium constant change?
The equilibrium constant is a constant at a given temperature and does not change unless the temperature changes. However, the concentrations (or pressures) of the reactants and products can change, which will affect the value of the equilibrium constant.
5. How can equilibrium expressions be used to predict the direction of a reaction?
If the value of the equilibrium constant is greater than 1, the reaction favors the products at equilibrium. If the value is less than 1, the reaction favors the reactants at equilibrium. This information can be used to predict the direction in which a reaction will proceed to reach equilibrium.
  • Chemistry
