MHB Acute angle of right triangles
  • Thread starter Thread starter mathmari
    Angle Triangles
The discussion centers on the properties of right triangles formed by a rectangle inscribed in a semicircle with a radius of 1. It is clarified that the acute angles of these triangles are not necessarily all equal to 45 degrees, as they depend on the rectangle's height. The area of the rectangle is set to 1, leading to a relationship between its height and width that can be solved using Pythagorean Theorem. Trigonometric methods can also be applied to find the angles, confirming that they can indeed be 45 degrees under certain conditions. Ultimately, both geometric and trigonometric approaches yield consistent results regarding the dimensions and angles of the triangles.
mathmari
MHB
Hey! :o
We have a rectangle inside a semicircle with radius $1$ :
From the midpoint of the one side we draw a line to the opposite vertices and one line to the opposite edge.
Are the acute angles of the right triangles all equal to $45^{\circ}$ ? (Wondering)
All four triangles are similar, aren't they? We have that the hypotenuse of each right triangle is equal to $1$, since it is equal to the radius of the circle.
I am stuck right now about the angles. (Wondering)
Mathematics news on Phys.org
A little thought should show you those statements are NOT true! There exist many different such rectangles, with many different such angles, depending on the height of the rectangle.
In this case the resulting smaller rectangles look like squares and that's why maybe I got confused. (Doh)
So when we know that the area of the big rectangle is $1$ and we want to calculate the length of the sides, it is not a good idea to use trigonometry, right? (Wondering)
It is better to do the following:
Let $x$ be the height and $w$ the width. Since $M$ is the midpoint we get that $w=2y$.
At the right triangle we can Pythagoras' Theorem and we get that $y=\sqrt{1-x^2}$.
The area of the big rectangle is $1$ so we get that $x\cdot w=1 \Rightarrow x\cdot 2\sqrt{1-x^2}=1$ and from that eauation we can calculate $x$. Btw we would get the same result if we would consider the acute angles to be $45^{\circ}$, so in this case they are indeed like that.
Hey mathmari!
We can do it with trigonometry as well.
The width of the rectangle is $2\cos\phi$ and the height is $\sin\phi$, isn't it? (Thinking)
So the area is:
$$2\cos\phi \cdot \sin\phi = \sin(2\phi) =1\implies \phi=\frac\pi 4$$
Yep. That works as well. (Nod)
Thanks a lot! 😇
Here is a little puzzle from the book 100 Geometric Games by Pierre Berloquin. The side of a small square is one meter long and the side of a larger square one and a half meters long. One vertex of the large square is at the center of the small square. The side of the large square cuts two sides of the small square into one- third parts and two-thirds parts. What is the area where the squares overlap?
  • · Replies 59 ·
37K
