MFerguson
- 1
I just started using the Big_Integer library that is a part of the 202X version of ADA.
It is repeatedly described as an "arbitrary precision library" that has user defined implementation.
I was under the impression that this library would be able to infinitely calculate numbers of any length, but there is clearly a default limit of 300 digits.
Is there any way to get rid of this problem?
Here is some example code:
with Ada.Text_IO; use Ada.Text_IO;
with Ada.Real_Time; use Ada.Real_Time;
with Ada.Numerics.Big_Numbers.Big_Integers;
use Ada.Numerics.Big_Numbers.Big_Integers;
with Ada.Strings.Unbounded; use Ada.Strings.Unbounded;
procedure Test is
package Time_IO is new Fixed_IO(Duration);
start_time, end_time : Ada.Real_Time.Time;
elapsed_seconds : Ada.Real_Time.Time_Span;
solution : Unbounded_String;
rop : Big_Integer;
sum : Big_Integer := 0;
begin
start_time := Ada.Real_Time.Clock;
for i in 1..700 loop
rop := To_Big_Integer(i) ** Natural(i);
sum := sum + rop;
end loop;
solution := To_Unbounded_String(sum'Image); end_time := Ada.Real_Time.Clock;
elapsed_seconds := end_time - start_time;
Put("Solution: " & solution'Image); New_Line; New_Line;
Put("Program completed in ");
Time_IO.Put(To_Duration(elapsed_seconds), Fore => 0, Aft => 3);
Put(" seconds");
end BigTest;
