MHB Adam's question via email about Laplace Transforms
The discussion centers on solving the initial value problem (IVP) using Laplace Transforms for the equation dy/dt + 11y = 3t with the initial condition y(0) = 5. The solution process involves taking the Laplace Transform, applying partial fractions, and finding the constants A, B, and C. There are corrections made regarding arithmetic errors in the initial calculations, leading to the correct general solution y(t) = (602/121)e^(-11t) + (3/11)t - (3/121). The conversation highlights the challenges of using the Laplace Transform method and the importance of careful arithmetic in solving differential equations.
Prove It
MHB
Solve the following IVP using Laplace Transforms:
$\displaystyle \frac{\mathrm{d}y}{\mathrm{d}t} + 11\,y = 3\,t, \quad y\left( 0 \right) = 5$
Take the Laplace Transform of the equation:
$\displaystyle \begin{align*} s\,Y\left( s \right) - y\left( 0 \right) + 11\,Y\left( s \right) &= \frac{3}{s^2} \\
s\,Y\left( s \right) - 5 + 11\,Y\left( s \right) &= \frac{3}{s^2} \\
\left( s + 11 \right) Y\left( s \right) &= \frac{3}{s^2} + 5 \\
Y\left( s \right) &= \frac{3}{s^2 \,\left( s + 11 \right) } + \frac{5}{s + 11} \end{align*}$
Apply Partial Fractions:
\frac{A}{s} + \frac{B}{s^2} + \frac{C}{s + 11} &\equiv \frac{3}{s^2 \,\left( s + 11 \right) } \\
A\,s\left( s + 11 \right) + B \left( s + 11 \right) + C\,s^2 &\equiv 3
\end{align*}$
Let $\displaystyle s = 0 \implies 11\,B = 3 \implies B = \frac{3}{11}$
Let $\displaystyle s = -11 \implies 121\,C = 3 \implies C = \frac{3}{121}$
Then $\displaystyle A\,s\left( s + 11 \right) + \frac{3}{11} \left( s + 11 \right) + \frac{3}{121}\,s^2 \equiv 3$
Let $\displaystyle s = 1$
12\,A + \frac{36}{11} + \frac{3}{121} &= 3 \\
12\,A + \frac{396}{121} + \frac{3}{121} &= \frac{33}{121} \\
12\,A &= -\frac{366}{121} \\
A &= -\frac{61}{242}
\end{align*}$
So
Y\left( s \right) &= -\frac{61}{242}\left( \frac{1}{s} \right) + \frac{3}{11} \left( \frac{1}{s^2} \right) + \frac{3}{121} \left( \frac{1}{s + 11} \right) + 5 \left( \frac{1}{s + 11 } \right) \\
Y\left( s \right) &= -\frac{61}{242} \left( \frac{1}{s} \right) + \frac{3}{11} \left( \frac{1}{s^2} \right) + \frac{608}{121} \left( \frac{1}{s + 11} \right) \\
y\left( t \right) &= -\frac{61}{242} + \frac{3}{11}\,t + \frac{608}{121}\,\mathrm{e}^{-11\,t}
\end{align*}$
Mathematics news on Phys.org
Let me, yet again, state my dislike for the "Laplace Transform Method"! And, in fact, Prove It made a slight arithmetic error
(easy to do with something as complicated as "Laplace Transform")
that resulted in an incorrect answer:
if y(t)= 61/242+ (3/11)t+ (608/121)e^{-11t} then
y'(t)= 3/11- (608/11)e^{-11t}
11y= 61/22+ 3t+ (608/11)e^{-11t}
so y'(t)+ 11t= 6/22+ 61/22+ 3t= 67/22+ 3t, not "3t".
It is far easier just to recognize that this is a linear differential equation with constant coefficients. Its "characteristic equation" is r+ 11= 0 so r= -11. The general solution to the associated homogeneous equation is y(t)= Ce{-11t} where C can be any constant.
Since the "non-homogeous" part is a linear polynomial, 3t, we look for a solution to the entire equation of the form y(t)= At+ B, for constants A and B. Then y'= A so the equation becomes A+ 11(At+ B)= 11At+ A+ 11B= 3t. In order for that to be true for all t, we must have both 11A= 3 and A+ 11B= 0. So A= 3/11 and then 3/11+ 11B= 0. B= -3/121.
The general solution to the entire equation is y(t)= Ce^{-11t}+ (3/11)t- 3/121. Since we want y(0)= 5, we must have 5= C+ 3/121 so C= 5- 3/121= 605/121- 3/121= 602/121.<br /> <br /> The solution is <div style="text-align: left"><span style="font-family: 'Verdana'">y(t)= (602/121)e^{-11t}+ (3/11)t- 3/121.<br /> <br /> Check: y&amp;#039;(t)= -(602/11)e^{-11t}+ 3/11 while 11y(t)= (602/11)e^{-11t}+ 3t- 3/11<br /> <br /> y&amp;#039;(t)+ 11t= 3t.<br /> </span>&#8203;</div>
y&#039;(t)= 3/11- (608/11)e^{-11t}
so y&#039;(t)+ 11t= 6/22+ 61/22+ 3t= 67/22+ 3t, not "3t".
<span style="font-family: 'Verdana'"><br /> <br /> Thanks for pointing out my error Hallsofivy. Adam is one of my students, and the topic they are learning is Laplace Transforms, so he will have to use that method.</span>
<br /> <br /> You also have an arithmetic error. When $\displaystyle t = 5$ you end up with $\displaystyle 5 = C - \frac{3}{121} \implies C = 5 + \frac{3}{121} = \frac{608}{121}$.<br /> <br /> I also see where my mistake was in the initial Laplace Transform. The easiest way to evaluate A is to look at the coefficient of $\displaystyle s^2 $, which gives<br /> <br /> $\displaystyle A + \frac{3}{121} = 0 \implies A = -\frac{3}{121} $.<br /> <br /> Thus<br /> <br /> $\displaystyle \begin{align*}<br /> Y\left( s \right) &amp;= -\frac{3}{121}\left( \frac{1}{s} \right) + \frac{3}{11}\left( \frac{1}{s^2} \right) + \frac{3}{121} \left( \frac{1}{s + 11} \right) + 5 \left( \frac{1}{s + 11 } \right) \\<br /> &amp;= -\frac{3}{121} \left( \frac{1}{s} \right) + \frac{3}{11} \left( \frac{1}{s^2} \right) + \frac{608}{121} \left( \frac{1}{s + 11 } \right) \\<br /> \\<br /> y\left( t \right) &amp;= -\frac{3}{121} + \frac{3}{11}\,t + \frac{608}{121}\,\mathrm{e}^{-11\,t}<br /> \end{align*}$<br /> <br /> and this is definitely correct.
Argh! Arithmetic! I never was any good at that!
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
