MHB Add Up Numbers: Get to 21 or Stop at 0
  • Thread starter Thread starter MMOne
    Numbers
The discussion revolves around a C++ program that prompts users to enter a number between 1 and 11, stopping when the user inputs 0 or when the total exceeds 21. The initial code provided has issues, particularly with the logic for displaying messages at the end. The user seeks assistance to correct these problems. A revised version of the code is presented, which initializes the total correctly and uses a loop to handle user input effectively. In this version, the program checks for valid input, updates the total, and terminates when the conditions are met, displaying the final total to the user. Key improvements include proper initialization of variables and clear exit conditions for the loop.
MMOne
Ask the user for a number between 1 and 11; stop asking when the user enters 0 OR when the total goes over 21. Display the total on the screen. For example:
#include<iostream>
#include<cmath>
using namespace std;
int main(){
int num, total;
cout << "Enter a number between 1 and 11 (0 to stop): ";
cin >> num;
cout << num << endl;
while((num > 0)&&(num < 12)){
total = total + num;
while ((num == 0) || (total > 21)){
cout << "Your total was " << total << endl;
cout << "Thanks for playing!" << endl;
return 0;
When I compile it will not provide the messages at the end. Not sure how to do this my code might just be sloppy. Any help would be appreciated.
Technology news on Phys.org
This is how I'd code it. I didn't compile and run it, though.
Code:
#include <iostream>
#include <cmath>
int main()
    int num;
    int total = 0;
    int quit = 0;
    while (!quit) {
        cout << "Enter a number between 1 and 11 or 0 to quit." << endl;
        cin >> num;
        if (num == 0)
          quit = 1;
        else if (num < 1 || num > 11)
                cout << "Invalid number." << endl;
        else {
             if (total > 21)
               quit = 1;
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
I am trying to run an .ipynb file and have installed Miniconda as well as created an environment as such -conda create -n <env_name> python=3.7 ipykernel jupyter I am assuming this is successful as I can activate this environment via the anaconda prompt and following command -conda activate <env_name> Then I downloaded and installed VS code and I am trying to edit an .ipynb file. I want to select a kernel, via VS Code but when I press the button on the upper right corner I am greeted...
