md01
- 2
I have the following program. I cannot figure out how to Add two-digit input and three-digit output capacity to it though.
; This program is designed to demonstrate the use of subroutines in
; programming.
; This file is phase 3 and introduces a multiply subroutine.
; Current support subroutines include : PMPTOUT, MULT, ATOI, ITOA
.ORIG x3000 ; load the program here
; Request factor1 from the user
; To be retrieved from R0 according to convention
AND R0,R0,#0
; Call prompt subroutine and output PROMPT1
LEA R3,PROMPT1
JSR PMPTOUT
TRAP x20 ; Use GETC to retrieve user character entry into R0
TRAP x21 ; Echo the entered factor
; Convert factor1 to an integer
; Use R2 to convert ASCII factor1 to an integer, store in R4 when done
AND R2,R2,#0 ; Clear R2
ADD R2,R0,#0 ; Load R2 with the ASCII value of factor1
JSR ATOI
ADD R4,R4,R2
LD R0,NewLine ; Go to a clean line for the next input
TRAP x21
; Request factor2 from user
AND R0,R0,#0
; Call prompt subroutine and output PROMPT2
LEA R3,PROMPT2
JSR PMPTOUT
; Convert factor2 to an integer
; Use R2 to convert ASCII factor2 to an integer, store in R5 when done
JSR ATOI
ADD R5,R5,R2
TRAP x21
; Perform multiplication with MULT subroutine
; Registers R4 and R5 correctly contain two integer factors here.
; R6 contains the integer product.
JSR MULT
; Use prompt writing subroutine to announce result
LEA R3,RESULT
JSR PMPTOUT
; Display the result of the multiplication on a clean line
JSR ITOA
TRAP x21 ; Write the product to the display
TRAP x25 ; HALT the processor
PMPTOUT ST R7,SaveR7
AND R0,R0,#0
ADD R0,R3,R0
TRAP x22 ; Call PUTS
LD R7,SaveR7
RET
; Multiply subroutine
; Expects factor1 in R4 and factor2 in R5
; Returns the product in R6
MULT AND R6,R6,#0 ; Clear R6 to hold result of multiplication
AGAIN ADD R6,R6,R4
ADD R5,R5,#-1
BRp AGAIN
RET
; Subroutine to convert ASCII character to an integer
; This routine uses R2 as a holding register for the correction
ATOI ST R3,SaveR3
AND R3,R3,#0 ; Clear R3
LD R3,ASCII ; Load ASCII correction into R3
NOT R3,R3 ; Form 1s complement
ADD R3,R3,#1 ; Form 2s complement
ADD R2,R2,R3 ; ACSII correction, R2 now contains integer for
; math operations
LD R3,SaveR3
RET
ITOA ST R3,SaveR3
AND R0,R0,#0 ; Clear R0 for product display
ADD R0,R6,R0 ; Load product integer into R0
AND R3,R3,#0 ; Clear R3 to ready ASCII correction
ADD R0,R0,R3 ; Make integer an ASCII character for output
LD R3,SaveR3
RET
; MEMORY AREA
NewLine .FILL x000A
ASCII .FILL x0030
SaveR7 .FILL x0000
SaveR3 .FILL x0000
PROMPT1 .STRINGZ "Enter the first factor\n"
PROMPT2 .STRINGZ "Enter the second factor\n"
RESULT .STRINGZ "The product of the factors is :\n"
.END
; End of
; programming.
AND R0,R0,#0
LEA R3,PROMPT1
JSR PMPTOUT
JSR ATOI
ADD R4,R4,R2
TRAP x21
AND R0,R0,#0
LEA R3,PROMPT2
JSR PMPTOUT
JSR ATOI
ADD R5,R5,R2
TRAP x21
JSR MULT
LEA R3,RESULT
JSR PMPTOUT
JSR ITOA
AND R0,R0,#0
ADD R0,R3,R0
LD R7,SaveR7
RET
AGAIN ADD R6,R6,R4
ADD R5,R5,#-1
BRp AGAIN
RET
ATOI ST R3,SaveR3
; math operations
LD R3,SaveR3
RET
ITOA ST R3,SaveR3
LD R3,SaveR3
RET
; MEMORY AREA
NewLine .FILL x000A
ASCII .FILL x0030
SaveR7 .FILL x0000
SaveR3 .FILL x0000
.END
; End of
