Adding a 2nd Secondary coil & effects
In summary, the conversation discusses the use of an induction heater in cooking and the effects of adding additional loads. It is mentioned that the power to the induction oscillator will be regulated to prevent overloading and that thicker or multiple conductors may be shielded due to the skin depth at the AC frequency used. The conversation also raises questions about the effect of stacking plates and the potential for added impedance on the primary coil.
roro36
27
Hi,
We have an induction heater, like a stove top one, not industrial.
I want to understand what happens when an additional load is added that it isn't intended to receive.
A plate goes on the induction warmer, it gets heated up, then removed and another plate takes it place.
What happens if the plates are stacked, i.e. 2 at a time, or 3 or more?
Surely, the induction will continue to all the plates, and what effect would this have on the current/power seen by the primary coil?
Depending on what feedback the machine uses to monitor the primary, if any at all, could the additional plates add extra impedance and force the primary to work harder, or does the impedance drop and create a higher current?
Thanks for any assistance.
Likes Aman Poddar
Induction cooking involves using an AC magnetic field to induce eddy currents in the base of a conductive pan.
At the AC frequency used, the skin depth in the conductor will limit the depth of penetration and so shield thicker or multiple conductors.
The power to the induction oscillator will be regulated which will prevent overloading.
Likes Aman Poddar
FAQ: Adding a 2nd Secondary coil & effects
What is the purpose of adding a 2nd secondary coil?
Adding a 2nd secondary coil allows for increased voltage and current output in a transformer. It can also be used to create a step-up or step-down transformer, depending on how the coils are arranged.
How does adding a 2nd secondary coil affect the overall performance of a transformer?
The addition of a 2nd secondary coil can increase the efficiency and power handling capabilities of a transformer. It can also improve the voltage regulation and reduce losses.
Can adding a 2nd secondary coil have any negative effects?
In some cases, adding a 2nd secondary coil can lead to increased leakage inductance and higher losses. It is important to carefully design and test the transformer to ensure optimal performance.
What are some considerations when adding a 2nd secondary coil?
When adding a 2nd secondary coil, it is important to consider the number of turns, the gauge of the wire, and the placement of the coil. These factors can affect the voltage and current output, as well as the overall performance of the transformer.
Are there any other benefits of adding a 2nd secondary coil?
In addition to increasing voltage and current output, adding a 2nd secondary coil can also improve the frequency response and reduce distortion in a transformer. This can be beneficial in applications that require precise and clean power output.
