Adding a small extra potential to a simple harmonic oscillator
In summary, the conversation is about a question regarding the modified simple harmonic oscillator and the use of first order perturbation theory to calculate the change in ground state energy. The perturbed potential is still a harmonic oscillator with a shifted frequency and the exact energy levels can be found using this information. The person being asked for help suggests looking up perturbation theory in a textbook and mentions that the first order energy shift is the expectation value of the perturbation.
kramleigh
Hi,
I've been scouring through many textbooks to try find some kind of solution to a question I have been asked for a problem sheet and was wondering if any1 would be able to help. The question is as follows;
The simple harmonic oscillator with hamiltonian H = (p^2/2m) + (1/2(mw^2x^2) is modified by adding a small extra potential V(x) = (1/2(ma^2x^2)). Use the first order perturbation theory to calculate the change in the ground state energy. How does this estimate differ from the exact result?
Unfortunately, I don't think we've covered it clearly enough in our lectures and I can't quite find anything specific enough in textbooks to answer it, so any help would be much appreciated.
Cheers
The obvious observation here is that the perturbed potential is still just a harmonic oscillator potential but with a shifted frequency. That should immediately tell you what the exact energy levels are. Now the remaining question is do you know how to do first order perturbation theory. I'm sure the details are in your book, just look up perturbation theory. The answer is very simple: the first order energy shift is just the expectation value of the perturbation.
FAQ: Adding a small extra potential to a simple harmonic oscillator
What is a simple harmonic oscillator?
A simple harmonic oscillator is a physical system that follows the basic laws of harmonic motion, meaning it oscillates back and forth around a central equilibrium point with a constant frequency and amplitude. It can be described mathematically using Hooke's law and the equation for simple harmonic motion.
How does adding a small extra potential affect a simple harmonic oscillator?
Adding a small extra potential to a simple harmonic oscillator changes the equilibrium position and affects the frequency and amplitude of the oscillation. This can also result in the oscillator exhibiting new behaviors, such as anharmonic motion or bifurcation.
What is the purpose of adding a small extra potential to a simple harmonic oscillator?
The purpose of adding a small extra potential to a simple harmonic oscillator is to study how the system responds to external influences and to explore the different behaviors that can arise. It can also provide insights into more complex systems and phenomena in nature.
How is the additional potential usually represented in mathematical models of a simple harmonic oscillator?
The additional potential is typically represented as a term in the equation of motion for the simple harmonic oscillator. This can be in the form of a constant, a function of time, or a function of the position of the oscillator.
What are some real-world examples of a simple harmonic oscillator with an added potential?
Examples of simple harmonic oscillators with an added potential include a mass on a spring with friction, a pendulum with air resistance, and an electrical circuit with a resistor and capacitor. These systems exhibit simple harmonic motion, but the added potential introduces new factors that affect their behavior.
