Adding Acids or Bases to Buffered Solutions
Once you have the initial amounts, you can calculate the amount of H+ ions added by multiplying the volume of HCl added (6.90 mL) by its concentration (0.480M). This will give you the amount of moles of H+ ions added.3. Using the initial amounts of HAc and Ac^{-}, you can calculate the new amounts after adding the H+ ions. This will give you the final amounts of HAc and Ac^{-}.4. Using the final amounts, you can plug them into the Henderson-Hasselbalch equation again to calculate the new pH. The change in pH will be the difference between the initial pH of 5.00 and the new pH.In summary,
quicknote
1,986
A beaker with 110 mL of an acetic acid buffer has a pH of 5.00 is sitting on a benchtop. The total molarity of acid and conjugate base in this buffer is 0.1 M. A student adds 6.90 mL of a 0.480M HCl solution to the beaker. How much will the pH change? The pK_a of acetic acid is 4.76.
My steps:
H + CH3COO <--> CH3COOH
1. find the initial mols of the conjugate acid (Not sure this is right):
mols =0.1*0.110
= 0.011 moles of acetic acid
2. inital mols of the conjugate base would be the same 0.011 moles because of a one to one ratio.
3. amount of H+ ions added:
0.480*0.0069 = 0.003312 moles
4. Final moles of conjugate base:
0.011-0.003312 = 0.007688 moles
5. final moles of acid
0.011+0.003312 = 0.014312
6. calculation of new pH...used Hasselbach equation:
[tex]pH = pK_a + log \frac{[Conjugate Base]}{[Conjugate Acid]} [/tex]
[tex]pH = 4.76 + log \frac{[0.007688]}{[0.014132]} [/tex]
=4.50
Therefore change in pH is 0.50
I think there is something wrong with my initial mols. "The total molarity of acid and conjugate base in this buffer is 0.1 M." I'm not sure how to calculated it based on this info.
Any help will be much appreciated. Thanks!
quicknote said:
A beaker with 110 mL of an acetic acid buffer has a pH of 5.00 is sitting on a benchtop. The total molarity of acid and conjugate base in this buffer is 0.1 M. A The pK_a of acetic acid is 4.76.
My steps:
mols =0.1*0.110
you know the buffer has a pH of 5.00 ([itex]pK_{a}[/itex])and [tex][HAc] + [Ac^{-}] = 0.1 M[/tex]
using the equation of Hendersson-Hasselbalch:
you can determine the ratio [tex]\frac {[Ac^{-}]} {[HAc]}[/tex].
This will give you the initial amount of [itex]HAc[/itex] and [itex]Ac^{-}[/itex].
Your steps are correct, but there is a small error in your initial mols calculation. The total molarity of acid and conjugate base in the buffer is 0.1 M, which means that the combined molarity of acetic acid and acetate ions is 0.1 M. So, the initial mols of the conjugate acid and base should be calculated as follows:
- Initial mols of conjugate acid (acetic acid): 0.1 * 0.11 = 0.011 moles
- Initial mols of conjugate base (acetate ions): 0.1 * 0.11 = 0.011 moles
Other than that, your calculations and steps are correct and your final pH calculation is also correct. The change in pH is indeed 0.50, as you have calculated. Keep up the good work!
Related to Adding Acids or Bases to Buffered Solutions
What is a buffered solution?
A buffered solution is a solution that resists changes in pH when small amounts of acid or base are added to it. It contains a weak acid and its conjugate base, or a weak base and its conjugate acid, which work together to maintain a relatively constant pH.
What happens when acids or bases are added to a buffered solution?
When acids or bases are added to a buffered solution, the pH of the solution remains relatively constant due to the presence of the weak acid and its conjugate base or weak base and its conjugate acid. This is known as the buffer capacity of the solution.
How do I calculate the pH of a buffered solution?
To calculate the pH of a buffered solution, you can use the Henderson-Hasselbalch equation: pH = pKa + log([conjugate base]/[weak acid]). The pKa value is the negative logarithm of the acid dissociation constant, and can be found in a reference table. The concentrations of the conjugate base and weak acid can be determined from the initial concentrations of the components in the buffered solution.
Can I add large amounts of acid or base to a buffered solution?
No, it is not recommended to add large amounts of acid or base to a buffered solution. While the buffer capacity of the solution can resist small changes in pH, adding too much acid or base can overwhelm the buffer and cause a significant change in pH.
What are some common examples of buffered solutions?
Some common examples of buffered solutions include blood, which is buffered by the carbonic acid/bicarbonate buffer system, and household ammonia, which is buffered by the ammonia/ammonium chloride buffer system. Many biological systems also use buffered solutions to maintain a stable pH, such as the stomach, which uses hydrochloric acid and bicarbonate to buffer stomach acid.
